Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on April 21, 2008, 5:13 am
Please log in for more thread options i have two router in the same site A/ B but for both Wan port can not communicate with each, can anyone please help . ^O^ Router A Building configuration... Current configuration : 6357 bytes ! ! No configuration change since last restart ! version 12.4 no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec localtime show-timezone year service timestamps log datetime msec localtime show-timezone year service password-encryption ! hostname iRobotHK-IPeFR-2811 ! boot-start-marker boot-end-marker ! card type e1 0 0 logging buffered 51200 debugging enable secret 5 $1$odnJ$/iCcIBspGsl4W1jz3pmMu. ! no aaa new-model clock timezone HK 8 no network-clock-participate wic 0 no ip source-route no ip gratuitous-arps ! ! ip cef ! ! no ip domain lookup ip sla monitor 1 type echo protocol ipIcmpEcho 4.2.2.2 source-interface FastEthernet0/0 ip sla monitor schedule 1 life forever start-time now ! voice-card 0 no dspfarm ! ! ! ! ! ! ! ! ! ! ! ! ! controller E1 0/0/0 framing NO-CRC4 channel-group 1 timeslots 1-31 ! track 123 rtr 1 reachability ! class-map match-all high match access-group 130 class-map match-all voice match access-group 110 ! ! policy-map WAN-QoS class voice priority 204 set dscp ef class high set dscp af31 bandwidth remaining percent 64 class class-default set dscp default bandwidth remaining percent 8 random-detect ! ! ! ! interface FastEthernet0/0 ip address 192.168.96.48 255.255.255.0 ip access-group 150 in no ip redirects no ip unreachables no ip proxy-arp duplex auto speed auto ! interface FastEthernet0/1 no ip address shutdown duplex auto speed auto ! interface Serial0/0/0:1 no ip address encapsulation frame-relay IETF service-policy output WAN-QoS ! interface Serial0/0/0:1.105 point-to-point ip address 10.128.0.1 255.255.255.252 no ip redirects no ip unreachables no ip proxy-arp frame-relay interface-dlci 777 ! interface Serial0/1/0 no ip address shutdown clock rate 2000000 ! router eigrp 1 redistribute bgp 65002 metric 1544 10 255 1 1500 passive-interface default no passive-interface FastEthernet0/0 network 192.168.96.48 0.0.0.0 no auto-summary ! router bgp 65002 no synchronization bgp log-neighbor-changes network 192.168.96.0 redistribute eigrp 1 neighbor 10.128.0.2 remote-as 21326 no auto-summary ! ip route 0.0.0.0 0.0.0.0 192.168.96.254 track 123 ip route 4.2.2.2 255.255.255.255 192.168.96.254 permanent ! ! no ip http server ! ! ip prefix-list filter_out seq 5 permit 192.168.96.0/24 ! map-class frame-relay CIR-512 frame-relay cir 500000 frame-relay bc 64000 frame-relay be 0 frame-relay mincir 500000 service-policy output WAN-QoS logging trap warnings logging 192.168.165.10 access-list 98 permit 216.126.54.17 access-list 99 permit 192.168.163.18 access-list 110 permit ip any any dscp ef access-list 110 permit ip any any precedence critical access-list 130 permit udp any eq 4100 any access-list 130 permit udp any any eq 4100 access-list 130 permit udp any eq 5000 any access-list 130 permit udp any any eq 5000 access-list 130 permit udp any range 5200 5263 any access-list 130 permit udp any any range 5200 5263 access-list 130 permit ip any any dscp cs5 access-list 130 permit ip any any precedence flash access-list 130 permit ip any 192.168.160.0 0.0.1.255 access-list 130 permit ip any 192.168.163.0 0.0.0.255 access-list 130 permit ip any 192.168.162.0 0.0.0.255 access-list 130 permit ip any any access-list 150 deny ip any host 192.168.161.99 access-list 150 permit ip any any snmp-server community M0nit0r4me RW 99 snmp-server community int3qRo RO 98 snmp-server trap-source FastEthernet0/0 snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart snmp-server enable traps tty snmp-server enable traps xgcp snmp-server enable traps envmon snmp-server enable traps isdn call-information snmp-server enable traps isdn layer2 snmp-server enable traps isdn chan-not-avail snmp-server enable traps isdn ietf snmp-server enable traps atm subif snmp-server enable traps bgp snmp-server enable traps bstun snmp-server enable traps cnpd snmp-server enable traps config snmp-server enable traps dial snmp-server enable traps dlsw snmp-server enable traps dsp card-status snmp-server enable traps entity snmp-server enable traps frame-relay snmp-server enable traps frame-relay subif snmp-server enable traps hsrp snmp-server enable traps ipmobile snmp-server enable traps ipmulticast snmp-server enable traps msdp snmp-server enable traps pim neighbor-change rp-mapping-change invalid- pim-messa ge snmp-server enable traps pppoe snmp-server enable traps rsvp snmp-server enable traps rtr snmp-server enable traps stun snmp-server enable traps syslog snmp-server enable traps vtp snmp-server enable traps voice poor-qov snmp-server enable traps dnis snmp-server host 192.168.163.18 version 2c M0nit0r4me snmp-server host 216.126.54.17 M0nit0r4me route-map bgp_filter_out permit 10 match ip address prefix-list filter_out ! ! ! ! control-plane ! ! ! ! ! ! ! ! line con 0 exec-timeout 15 0 logging synchronous login local line aux 0 login local line vty 0 4 logging synchronous login local line vty 5 15 exec-timeout 5 0 logging synchronous login local ! scheduler allocate 20000 1000 ntp clock-period 17180204 ntp server 192.5.41.40 ! end Router B Building configuration... Current configuration : 2866 bytes ! version 12.2 service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname HK-1750-2KY2J ! enable secret 5 $1$DySA$ufLT5Fm/Vdakd.305Myo8/ ! memory-size iomem 15 mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 ip subnet-zero ! ! no ip domain-lookup ! ip audit notify log ip audit po max-events 100 ip cef ! class-map match-all Gold match access-group 100 class-map match-all Silver match access-group 101 ! ! policy-map QoS class Gold set ip dscp 40 priority 512 class Silver set ip dscp 24 bandwidth 512 class class-default fair-queue random-detect shape average 1024000 ! ! ! ! ! interface Tunnel1 ip unnumbered Ethernet0 tunnel source 192.168.1.2 tunnel destination 192.168.2.2 ! interface Ethernet0 description Link to HGC MPLS ,2M ip address 192.168.1.2 255.255.255.252 full-duplex service-policy output QoS ! interface FastEthernet0 description Link to HK 192_LAN ip address 192.168.96.49 255.255.255.0 speed auto ! router eigrp 1 redistribute static network 192.168.96.49 0.0.0.0 network 192.168.96.0 auto-summary eigrp stub connected static no eigrp log-neighbor-changes ! ip classless ip route 0.0.0.0 0.0.0.0 192.168.96.254 ip route 192.168.2.0 255.255.255.252 192.168.1.1 ip route 192.168.33.0 255.255.255.0 192.168.1.1 ip route 192.168.34.0 255.255.255.0 192.168.1.1 no ip http server ip pim bidir-enable ! ! access-list 98 permit 216.126.54.17 access-list 100 permit tcp host 192.168.96.140 any eq 7300 dscp cs5 access-list 100 permit udp host 192.168.96.140 any eq 7300 dscp cs5 access-list 101 permit ip host 192.168.96.50 host 192.168.33.50 dscp cs3 access-list 101 permit ip host 192.168.96.71 host 192.168.33.50 dscp cs3 access-list 101 permit ip host 192.168.96.72 host 192.168.33.50 dscp cs3 access-list 101 permit ip host 192.168.96.50 host 192.168.33.55 dscp cs3 access-list 101 permit ip host 192.168.96.71 host 192.168.33.55 dscp cs3 access-list 101 permit ip host 192.168.96.72 host 192.168.33.55 dscp cs3 ! snmp-server community int3qRo RO 98 snmp-server trap-source FastEthernet0 snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart snmp-server enable traps entity snmp-server host 216.126.54.17 M0nit0r4me banner motd ^C This is secret network,if u have not permission,pls logout now.^C ! line con 0 line aux 0 line vty 0 4 password cisco login local ! end | ||||||||||
| Similar Threads | Posted |
| EIGRP, Want to prevent any EIGRP traffic to a interface | January 23, 2006, 11:58 am |
| EIGRP and VRF | March 29, 2006, 3:30 pm |
| EIGRP Help | April 7, 2006, 10:36 am |
| BGP and EIGRP | April 21, 2008, 5:13 am |
| EIGRP and OSPF | July 24, 2005, 11:42 pm |
| crypto map eigrp help | September 12, 2005, 3:09 pm |
| EIGRP and its limits | October 6, 2005, 3:51 pm |
| question about eigrp | February 20, 2006, 3:47 pm |
| EIGRP Question. | May 7, 2006, 5:17 pm |
| EIGRP or OSPF over WAN | July 8, 2006, 1:17 am |
| eigrp doesn't need net mask ? | August 16, 2006, 6:05 pm |
| DSL, T1, GRE, EIGRP Failover | July 5, 2005, 11:39 am |
| EIGRP, BPG, and Redistribution | February 21, 2007, 9:27 am |
| problems with the hello to eigrp | March 9, 2007, 7:54 pm |
| EIGRP question. | March 15, 2007, 11:51 pm |
BGP and EIGRP
Yahoo!
Windows Live
del.icio.us
digg
Netscape
