Posted by Can2002 on February 17, 2007, 6:35 am
I've been trying to configure LLQ on an 877w for a while now with
little joy. I've tried matching classes on a range of criteria
including dscp and access lists. In each case I then assign these
classes to a policy map and then assign the policy map to my dialer
interface (PPPoA).
I can see that the classes are matching my traffic, but when I look at
the service policy statistics for the dialer interface, it shows no
packets matched against the priority queue.
I've pasted below my class and policy maps:
class-map match-any VoIP-Signalling
match access-group name VoIP-Signalling
class-map match-any VoIP-Voice
match access-group name VoIP-Voice
policy-map QOS-Default
class VoIP-Voice
priority 64
class VoIP-Signalling
bandwidth 20
class class-default
fair-queue
The access lists used to match the classes above are below:
ip access-list extended VoIP-Signalling
permit udp host 1.2.3.4 eq 5060 any
ip access-list extended VoIP-Voice
permit udp host 1.2.3.4 range 18000 18999 any
permit udp host 1.2.3.4 eq 4569 any
I've checked that the ACLs are matching the voice traffic:
show access-lists VoIP-Voice
Extended IP access list VoIP-Voice
10 permit udp host 1.2.3.4 range 18000 18999 any (1898
matches)
20 permit udp host 1.2.3.4 eq 4569 any
show access-lists VoIP-Signalling
Extended IP access list VoIP-Signalling
10 permit udp host 1.2.3.4 eq 5060 any (91 matches)
The Dialer interface has the following command added (trimmed for
posting):
Interface Dialer10
service-policy output QOS-Default
When I run 'show policy-map interface dialer 10' I see the following:
Dialer10
Service-policy output: QOS-Default
Class-map: VoIP-Voice (match-any)
1898 packets, 125472 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group name VoIP-Voice
5 minute rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 72
Bandwidth 64 (kbps) Burst 1600 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
Class-map: VoIP-Signalling (match-any)
96 packets, 50166 bytes
Match: access-group name VoIP-Signalling
5 minute rate 0 bps
Queueing
Output Queue: Conversation 73
Bandwidth 20 (kbps)Max Threshold 64 (packets)
(depth/total drops/no-buffer drops) 0/0/0
A couple of posts have raised similar questions - particularly whether
it's even possible to apply a policy map to a dialer interface.
Any pointers would be gladly received!
Chris
Posted by on February 17, 2007, 11:57 am
> interface (PPPoA).
> class VoIP-Voice
> priority 64
> bandwidth 20
> class class-default
> fair-queue
> matches)
> posting):
> Interface Dialer10
> Dialer10
> 5 minute rate 0 bps
> Queueing
> Strict Priority
> 5 minute rate 0 bps
> Queueing
My understanding is that this only works with
multilink ppp. I have not had the opportunity to try it out.
If you look at the documents very carefully the only examples
given are mppp ones and often in the documents specific
router models are mentioned which leads me to worry that
support is platform dependent.
On the other hand this may work.
pvc 0/38
vbr-nrt 240 240
tx-ring-limit 2
encapsulation aal5mux ppp dialer
dialer pool-member 1
service-policy output PM.to-internet
You NEED the vbr-nrt bit.
MAYBE you need also:-
interface Dialer0
Oh yes I remember.
My idea was to mark the packets in the dialer
then do crypto with QoS pre-classify
then hopefully the marked packets would be queued
somewhere, or something.
I can't figure it out.
One thing about this latter config (PVC) that I don't follow
is that the ATM interface has no clue about IP and
yet documents suggest that you apply an IP
based service policy to it. I find that baffling.
No - make that really, really really baffling.
It may work though.
Let us know. I have done some testing and it does seem to
be working but I did not do enough to be sure.
Posted by on February 17, 2007, 12:07 pm
Please log in for more thread options On 17 Feb, 16:57, B...@hotmail.co.uk wrote:
> > interface (PPPoA).
> > class VoIP-Voice
> > priority 64
> > bandwidth 20
> > class class-default
> > fair-queue
> > matches)
> > posting):
> > Interface Dialer10
> > Dialer10
> > 5 minute rate 0 bps
> > Queueing
> > Strict Priority
> > 5 minute rate 0 bps
> > Queueing
> pvc 0/38
> vbr-nrt 240 240
> tx-ring-limit 2
> interface Dialer0
> Oh yes I remember.
> It may work though.
> be working but I did not do enough to be sure.- Hide quoted text -
> - Show quoted text -
On the other hand,
Get a 2801 and put it inside your 877, not using the wireless.
Then you can do fine and beautiful traffic shaping and LLQ on the
2801's ethernet interfaces. That works very nicely for sure.
PS - LLQ does not work on BVIs.
In this case it does tell you when you type it in which is nice.
Posted by Can2002 on March 6, 2007, 1:52 pm
Please log in for more thread options On 17 Feb, 17:07, B...@hotmail.co.uk wrote:
> > > interface (PPPoA).
> > > class VoIP-Voice
> > > priority 64
> > > bandwidth 20
> > > class class-default
> > > fair-queue
> > > matches)
> > > posting):
> > > Interface Dialer10
> > > Dialer10
> > > 5 minute rate 0 bps
> > > Queueing
> > > Strict Priority
> > > 5 minute rate 0 bps
> > > Queueing
> > pvc 0/38
> > vbr-nrt 240 240
> > tx-ring-limit 2
> > interface Dialer0
> > Oh yes I remember.
> > It may work though.
> On the other hand,
Cheers for the responses,
I got to the bottom of it in the end; the policy map needs to be
applied to the ATM sub-interface, not the dialer!
It took a fair amount of digging, but anfter tweaking the settings it
kicked into gear!
Chris
| Similar Threads | Posted |
| Applying QOS on an 877W | February 17, 2007, 6:35 am |
| applying QoS on cisco 827 | February 10, 2005, 6:23 pm |
| Applying QoS on the Route Process Module RPM of the MGX ATM Switch | February 13, 2006, 3:47 pm |
| Another Question on the 877W | July 25, 2006, 6:35 am |
| 877W and Be Broadband | September 19, 2007, 5:48 am |
| Natting the DMZ on an 877w | November 21, 2007, 4:08 pm |
| NAT type of Cisco 877W | November 26, 2005, 8:14 pm |
| Using IPv6 on a Cisco 877W | October 21, 2006, 10:52 am |
| Bridging with a Cisco 877W | December 21, 2006, 1:11 pm |
| Newbie needs help with 877w router | December 27, 2006, 12:01 pm |
| Cisco 877W of 857W ? | May 23, 2008, 10:28 am |
| Cisco 877W and Demon | November 22, 2008, 9:39 am |
| Problem config Cisco 877w | October 26, 2005, 5:02 am |
| Cisco 877W Router ( Newbie ) | November 3, 2005, 7:28 pm |
| Green light on 877W router | February 12, 2006, 6:59 am |
> interface (PPPoA).
> class VoIP-Voice
> priority 64
> bandwidth 20
> class class-default
> fair-queue
> matches)
> posting):
> Interface Dialer10
> Dialer10
> 5 minute rate 0 bps
> Queueing
> Strict Priority
> 5 minute rate 0 bps
> Queueing
