Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Tom Pouce on September 12, 2006, 7:06 am
Please log in for more thread options Is it possible (without opening the router) to see if there is only one 16Mb flash simm in the router or it are 2 x 8 Mb Flash Simms. Which command can give this information? Kind Regards Tom | ||||||||||||||||
Posted by www.BradReese.Com on September 12, 2006, 3:51 pm
Please log in for more thread options You may wish to investigate: How to Determine the SIMM Configuration of a Cisco 3620 or 3640 Series Router: http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a0080104555.shtml Hope this helps. Brad Reese BradReese.Com - Cisco Jobs http://www.bradreese.com/hot-jobs.htm 1293 Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Cisco Resumes http://www.bradreese.com/cisco-resumes.htm | ||||||||||||||||
Posted by Eric on September 13, 2006, 1:45 pm
Please log in for more thread options On 12 Sep 2006 12:51:25 -0700, "www.BradReese.Com"
Hey Brad - That's a really cool procedure, but on my 3640s it shows the DRAM simm layout, not the flash simm layout, which is what the OP discussed. This procedure shows I've got 128meg of DRAM in four 32 meg banks, which is of course way too much to be the flash. - Eric | ||||||||||||||||
| Similar Threads | Posted |
| Amount of flash simms in 3640 | September 12, 2006, 7:06 am |
| Upgrading flash -> 32 mb. Cisco 3640 | July 22, 2005, 6:56 pm |
| Re: 3640 latest 124-16 wont fit in flash | August 18, 2007, 11:12 pm |
| Re: 3640 latest 124-16 wont fit in flash | August 19, 2007, 4:25 pm |
| Measure amount of network usage | May 27, 2008, 3:33 am |
| Large amount of dropped packets on FWSM in multicontext | December 5, 2006, 12:58 am |
| show amount of traffic passing throw interface | October 18, 2007, 10:41 am |
| 4 T1 WIC for 3640? | February 2, 2006, 4:23 pm |
| 3640 Router and NM-2FE | August 20, 2005, 4:04 am |
| Which image for a 3640. | February 20, 2006, 9:57 am |
| Parity RAM on 3640? | June 22, 2006, 7:25 am |
| SLB problems with IOS 12.4.10 on 3640 | September 19, 2006, 7:24 am |
| outbound nat on a 3640 | October 4, 2006, 5:54 pm |
| outbound NAT on a 3640 | October 4, 2006, 6:16 pm |
| Cisco 3640 with NM-4T1-IMA | October 9, 2006, 10:44 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
>Router:
>Hope this helps.
