Cisco Systems Aironet 1200 causing BSOD in XP clients!
Subject Author Date
Aironet 1200 causing BSOD in XP clients! Bob 11-23-05
Posted by Bob on November 23, 2005, 6:33 am
I have a problem with all my Cisco 1200's (they are currently running
12.3-7.JA1). I have been using a single SSID for years on a single
VLAN (so no VLAN's defined) with PEAP authentication, WPA and TKIP for
my internal wireless network. This authenticates against the Cisco
ACS Radius server. All works well.
Just recently, I enabled a guest wireless access SSID on the same
1200's, created a second VLAN for it and made it OPEN with no
authentication. All appears to work well except....
Several of my IBM Thinkpad and HP laptops get a BSOD (Blue screen of
death) in Windows XP when this is enabled. The error is
"IRQ_LESS_THAN_EQUAL" on the BSOD, which is commonly a driver
conflict. However, there never has been a conflict for years. If
they try to connect to the guest SSID, it will blue screen. They all
have the Intel Pro wireless 2100/B (Centinro) NIC in these laptops, so
I am not sure if that matters. It happened so far to 18 laptops when
they rebooted the next morning after my AP changes! There were a
couple that did NOT exhibit this problem. I'm trying to determine if
its a later driver revision that fixes it.
However, even if a later driver does work, it doesn't explain why an
Open/No encryption SSID being broadcast from an access-point would
cause any laptop to BSOD. I can connect these laptops just fine to
any old Linksys, Netgear, or whatever they have in hotels, airports
and bookstores without an issue. Most of those are unencrypted
networks too. Does anyone know if Cisco is aware of this problem? Is
there a fix? It's very reproducable, so surely somebody must have
seen it before.
My only thoughts about what could be different between a Cisco
broadcasting an SSID versus some generic AP, is that it has two SSID's
coming from the same wireless MAC address? Could that matter?
Perhaps the Intel wireless drivers are touchy in that regard? I don't
know...
-Bob
Posted by Bob on November 23, 2005, 10:04 pm
Found the solution to my own problem. It's a bug in the Intel
Pro/Wireless 2100 3B drivers. But even weirder, it manifests itself
only when using the word "guest" somewhere in your SSID on the
Aironet!! Go figure. I changed it to something else, and the BSOD's
stop. Updating the wireless driver also fixes it too.
Similar ThreadsPosted
Aironet 1200 causing BSOD in XP clients! November 23, 2005, 6:33 am
aironet 1200 April 9, 2006, 9:48 am
Aironet 1200 December 10, 2006, 2:58 pm
Cisco 1200 Aironet July 5, 2005, 4:54 am
Cisco Aironet 1200 March 12, 2007, 6:38 am
cant tftp aironet 1200 January 1, 2008, 2:21 am
Aironet 1200 ping problem August 5, 2005, 3:06 pm
Trunking: Aironet 1200 - Cat2950 December 14, 2005, 3:40 pm
Strange Aironet 1200 AP Behavior July 19, 2006, 10:21 am
Cisco Aironet 1200 and ssid July 24, 2006, 9:22 am
Aironet 1200 - Axis Camera May 21, 2008, 9:18 am
Aironet 1200 with Yagi range? May 28, 2008, 12:31 pm
Aironet 1200 - Inter-VLAN Routing HELP! January 12, 2006, 2:13 pm
Aironet 1200 AP as 1-port "Access Server" January 15, 2006, 11:37 pm
Cisco Aironet 1200 Access point August 24, 2006, 3:33 am
