Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Alun on May 30, 2008, 9:19 am
Please log in for more thread options am trying to access the Cluster Management Software from Firefox running under Windows XP. I can get to the web interface to click on the CMS link OK, but then run into the problem that it seems to require an ancient version of Java. I have 1.6 installed and it wants 1.3 or older. If I install an older version in parallel (which I have done for standalone Java apps in the past) it installs OK, but the Java control panel applet doesn't let me specify any other version than the current one for running Java applets in the browser, only for standalone Java apps. Any ideas? | ||||||||||||||||
Posted by Trendkill on May 30, 2008, 9:32 am
Please log in for more thread options Use the CLI. While I'm quite sure there is a way to get past the java problem, I don't think I'd bother. To answer your question, I think in IE there are some check boxes under 'advanced' that allow you to choose what java ver to use, but no clue on Firefox, and even then, I'm not sure any of that would work with such an old version. | ||||||||||||||||
Posted by Charles N Wyble on June 3, 2008, 4:27 am
Please log in for more thread options Trendkill wrote:
> Use the CLI. While I'm quite sure there is a way to get past the java > problem, I don't think I'd bother. Yeah definitely use the CLI. The vast majority of the community information and the stuff straight from cisco is all documented as CLI commands. It's a nice way to concisely represent info. I have 2 2924XL switches on my desk, and I'll be clustering them soon. I'll definitely be using the CLI. Charles | ||||||||||||||||
| Similar Threads | Posted |
| Accessing CMS on 2924XL switch | May 30, 2008, 9:19 am |
| Resetting My Catalyst 2924XL Switch... | November 14, 2006, 10:07 am |
| X2931 module in 2924XL switch | September 27, 2007, 11:55 am |
| 2924xl | October 18, 2007, 1:00 pm |
| Cisco 2924XL Packet Loss? | January 2, 2006, 1:45 pm |
| catalyst 2924xl; POST failure | January 18, 2006, 4:34 pm |
| Port activation delay on 2924XL | January 2, 2007, 12:28 am |
| Connecting Catalyst 3548 XL to 2924XL Problems | January 19, 2006, 4:52 pm |
| Re: 2924XL SNMP MAC Table Read Oddity | February 23, 2008, 12:56 pm |
| Re: Cisco 2924XL SNMP (MIBs & VLAN switching) | January 25, 2008, 1:38 pm |
| VPN Pix problem accessing outside | August 24, 2006, 1:35 pm |
| accessing the device | August 29, 2007, 4:49 pm |
| Problem accessing web server | July 19, 2005, 8:59 am |
| accessing hosts inside NAT | December 10, 2005, 7:02 am |
| Problem with accessing some sites | May 12, 2006, 4:22 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Any ideas?
