Cisco Systems AUX/Consol ports
Subject Author Date
AUX/Consol ports george.hakobyan 04-13-06
Posted by on April 13, 2006, 7:54 am
Hi
please help my to solve the problem!
I have 2 routers, trougt console cabel I have connect router1 (aux
port) to router2 (console port)
I want do telnet to router1 and connect to router2 consol port
please help my configure aux port
Regards
George.
Posted by Rainer Temme on April 13, 2006, 8:23 am
George,
in router1 you need to set the aux-port to have the same settings
as the console line of router2 (9600baud 8bit 1stop noparity is std)
this is done with
line aux 0
stopbits 1
databits 8
speed 9600
parity none
you want to make sure that console output of router2 is not interpreted
as login-attepmt to router1 so you add
line aux 0
no exec
eventually the aux-port was used to hold a ppp-modem connection, and
there is still a async-interface configured ... this needs to be deleted.
To find out the name ... do a
show line
the output should contain one line with Typ=AUX and a
certain Tty number.
do a
no interface Async XXX
where XXX is the Tty-number of the output of "show line".
Now, your AUX-line is prepared to be used.
Connect to your local AUX-line by
- telnetting to router1 and then (within router1)
telnet ROUTER1_IP 2000+XXX
ROUTER1_IP is router1's IP-address
2000+XXX is Number XXX plus 2000 so ... if XXX was 5 then use 2005
- If no accesslist is denying it
telnet router1 2000+XXX
from elsewhere in your network. (This should connect the telnet to the
AUX-port.)
Remember one other thing: for the connection from
router1-AUX to router2-CON ...
you need a _rollover_ cable !!!
not a straight cable,
and not a LAN-crossover cable.
(rollover is 1-8 2-7 3-6 4-5 5-4 6-3 7-2 8-1)
(straigh is 1-1 2-2 3-3 4-4 5-5 6-6 7-7 8-8)
(crossover is 1-3 3-1 2-6 6-2)
hope this helps ... Rainer
Posted by Rainer Temme on April 13, 2006, 8:28 am
oops, forgot this ...
add a
line aux 0
transport input all
Rainer
Posted by on April 17, 2006, 2:21 am
Hi Rainer,
First of all thank you for your respond
I hawe don this step
1.
line aux 0
stopbits 1
databits 8
speed 9600
parity none
no exec
2.
connect router1 aux port to router2 consol port via rollover cable
sh line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise
Overruns Int
0 CTY - - - - - 0 0 0/0
1 AUX 9600/9600 - - - - - 0 11170 0/0
* 2 VTY - - - - - 26 0 0/0
3 VTY - - - - - 2 0 0/0
4 VTY - - - - - 0 0 0/0
5 VTY - - - - - 0 0 0/0
6 VTY - - - - - 0 0 0/0
1/00 Digital modem - - - - - 0 129 0/0
1/01 Digital modem - - - - - 0 129 0/0
1/02 Digital modem - - - - - 0 125 0/0
1/03 Digital modem - - - - - 0 124 0/0
5/107 Digital modem - - - - - 0 104 0/0
Line(s) not in async mode -or- with no hardware support:
7-215, 600-647
I cane not find interface async xxx
George
Posted by Rainer Temme on April 18, 2006, 12:13 pm
george.hakobyan@gmail.com wrote:
> sh line
> Overruns Int
> 7-215, 600-647
George,
"show line" shows your aux-line as tty-1 therefore the corresponding
async-interface woule be "interface async 1" ...
if this interface does not exist in your config everything is already
in order. If it exists, you have to delete it with
conf term
no int asy 1
exit
Now, try a telnet your_routers_ip 2001
your_routers_ip is the ip-address of one of your
local interfaces (except NUL).
Rainer
Similar ThreadsPosted
871 and USB ports September 9, 2005, 11:58 am
ports in pix November 1, 2005, 6:44 pm
PIX & Ports August 18, 2006, 2:17 pm
QoS on some ports April 6, 2007, 8:23 am
PIX 501 LAN Ports May 5, 2008, 11:48 pm
protected ports December 15, 2005, 2:06 pm
AUX/Consol ports April 13, 2006, 7:54 am
trunk ports September 1, 2006, 6:46 pm
NAT doesn't seem to work on all ports June 14, 2005, 5:29 pm
range of ports in ACL on PIX? June 16, 2005, 2:53 pm
LANs and ports September 7, 2006, 1:21 pm
VPN Firewall ports September 8, 2006, 11:09 am
firewall ports October 1, 2006, 9:37 pm
Opening Ports December 6, 2006, 1:04 pm
USB ports on SUP32 March 30, 2007, 1:59 pm
