Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on February 13, 2007, 6:37 am
I have experiensed failover failure on the new instalation of pair of ASA 5510 7.2(2). I use multi context mode but actualy in Active/ Standby mode. Only the reason fro multi context is the preemtion option only supported in multiple mode. The problem is that after restart of the primary/activ box it fall in to state "failover off" or "could standby". Only recovery procedure to get the failover up and running is switch off the secondary box, restart the primary and finaly switch on the secondary again. This behavior was seen only when restarting the active. If I simulate other failure e.g. interface disconnect it works fine. Can someone advise if: 1. Configuration with single failover group is valid ? 2. If someone experienced similar behavior. Or have any idea. See the failover configuration: failover failover lan unit primary failover lan interface failover Ethernet0/3 failover polltime unit 2 holdtime 10 failover key ***** failover link failover Ethernet0/3 failover interface ip failover 192.168.254.1 255.255.255.252 standby 192.168.254.2 failover group 1 preempt polltime interface 2 holdtime 10 Thanks for any ideas. Regards Roman | |||||||
| Similar Threads | Posted |
| ASA failover failure | February 13, 2007, 6:37 am |
| cisco ASA/PIX failover and VPN, failover IP access problem | August 27, 2008, 11:34 am |
| PRI to BRI multilink failure. | July 13, 2005, 9:24 pm |
| Re: Dynamic NAT Failure | September 1, 2006, 9:53 am |
| Dynamic NAT Failure | August 28, 2006, 11:54 am |
| MIB Discovery Failure | October 2, 2007, 2:08 pm |
| 1811 failure | October 29, 2009, 9:40 am |
| 2621XM - np ip inspect causes failure | December 13, 2005, 10:36 am |
| Pix 515 does not recover from, Power Failure | July 24, 2006, 12:28 pm |
| Temporary failure on T.38 fax calls | February 7, 2007, 5:48 am |
| VPN 3005 to IAS authentication failure... | March 5, 2007, 2:15 pm |
| VPN 3005 to IAS authentication failure... | March 5, 2007, 2:16 pm |
| Failure after switch warms up | July 19, 2007, 7:56 pm |
| RDP thru Cisco VPN client and thru 501 Failure | August 5, 2008, 3:52 pm |
| Wired dot1x failure | April 30, 2009, 4:22 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
