Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by rossk on May 1, 2008, 12:15 am
Please log in for more thread options the outside interface IP that is encrypted inside the packet to another IP. Basically there is a router in front of the ASA and it gets a number of 192.168.1.5 for example. When the ASA sends the packet over the VPN tunnel encrypted it of course says the source is 192.168.1.5. I basically want to change that number to represent the outside IP address. Is this possible? The IP header on the packet does show the static outside address just not the encrypted ip header field. | ||||||||||||||||
Posted by News Reader on May 1, 2008, 9:21 am
Please log in for more thread options rossk wrote: Encapsulation is what is being discussed, not encryption. Outside interface address of which device, the ASA or the router? You are referring to changing an inner (encapsulated) address here, but later refer to changing an outer (encapsulating) address. >Basically there is a router in front of the ASA and it
> gets a number of 192.168.1.5 for example. When the ASA sends the > packet over the VPN tunnel encrypted it of course says the source is > 192.168.1.5. I basically want to change that number to represent the "Of course" because the router uses NAT, or "of course" because the router is doing the encapsulation rather than the ASA? This says you want to change an outer (encapsulating) address. > outside IP address. Is this possible? The IP header on the packet
> does show the static outside address just not the encrypted ip header > field. It would be best if you stated: * Which device is doing the encapsulation. * Are you using NAT, and if so, on which device. * Which ESP Mode is currently being used with your IPSec transform (Tunnel, Transport). * Are you using GRE. Best Regards, News Reader | ||||||||||||||||
| Similar Threads | Posted |
| ASA 5510 | June 8, 2006, 9:37 am |
| ASA 5510 and qos | October 19, 2006, 3:59 am |
| VPN to ASA 5510 | August 31, 2007, 9:13 am |
| asa 5510 | February 20, 2008, 7:06 pm |
| ASA 5510 QoS | June 24, 2008, 12:07 pm |
| Very slow ftp on ASA 5510 | August 8, 2006, 5:16 am |
| ASA 5510 FTP Issue | August 20, 2006, 9:48 pm |
| Cisco ASA 5510 | September 26, 2006, 6:10 am |
| PASV FTP through ASA 5510 | October 3, 2006, 3:14 pm |
| ASA 5510 Issue | January 5, 2007, 10:06 am |
| ASA 5510 UDP NAT problem | February 6, 2007, 9:29 am |
| ASA 5510 as a router? | May 17, 2007, 5:21 pm |
| Passwords on ASA 5510 | May 22, 2007, 6:53 pm |
| ASA 5510 doesn't put through traffic. | June 6, 2007, 7:05 am |
| Authenticate 5510 against AD | November 20, 2007, 12:03 pm |
ASA 5510 and NAT to Site-to-Site
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> another IP.
