Cisco Systems ASA 5510 WebVPN issue
Subject Author Date
ASA 5510 WebVPN issue Alex Tech 09-22-08
Posted by Alex Tech on September 22, 2008, 12:28 pm
Hi all,
I use ASA WebVPN with portforwarding feature to ensure terminal services
access to some internal servers.
Everything worked fine untill few days ago...now I can connect and log-me in
but when i launch the microsoft remote desktop it does not work and in the
java applet (where normally there are the list of the servers with port
forward enabled) stop working and a "disconnect" appear.
I really don't understand what appen!
Bad Java updates in these days?
Low memory available to run WebVPN ?
I'm going to try a reboot...
any suggest?
thanks
Alex
Posted by Artie Lange on September 22, 2008, 12:29 pm
Alex Tech wrote:
> Hi all,
> any suggest?
> thanks
Any log messages when you try to log in?
Posted by Alex Tech on September 22, 2008, 12:57 pm
from the logs seems it tries to resume some old connection that were idles.
I've rebooted and now it works...the system was up from 55 days...
there is a manner to "reset" the webvpn service without rebooting the
firewall??
i'll try to investigate better tomorrow
Thanks
Alex
Similar ThreadsPosted
ASA 5510 WebVPN issue September 22, 2008, 12:28 pm
ASA 5510 FTP Issue August 20, 2006, 9:48 pm
ASA 5510 Issue January 5, 2007, 10:06 am
Webvpn. April 18, 2006, 5:47 am
WebVPN NAT-T August 10, 2006, 11:00 pm
webvpn ssl June 13, 2005, 3:31 pm
WebVPN problems September 27, 2005, 3:18 am
VPN3005 and SSL/WebVPN October 12, 2005, 4:20 pm
WebVPN on Cisco 877 August 28, 2006, 2:50 am
Cisco WebVPN: have you used it? November 13, 2006, 2:31 pm
WebVPN ASA5510 March 5, 2008, 3:42 pm
WebVPN missing on Cisco PIX 515 7.1.2? April 19, 2006, 2:07 pm
How do I translate ALL WebVPN messages May 2, 2006, 4:02 am
WebVPN URL getting time out error May 3, 2006, 6:39 pm
How to create a WebVPN group? May 16, 2006, 1:42 pm
