7204VXR and 10 gig ethernet?
Threaded View
We've got a 7204VXR router with an NPE-400 and a 1-port gigabit ethernet card, connecting to our upstream provider. We are looking into moving to a new provider on a 10 gigabit ethernet link, keeping the original connection as a backup.
Can the 7204VXR support 10 gig ethernet? Is there enough capacity to support 10 gig ethernet and the original 1 gig ethernet?
Re: 7204VXR and 10 gig ethernet?
Steve Pfister wrote:
 Do a search for routerperformance.pdf.
 According to that a 7200/NPE-400 can shift about 420 Kpps and about 521
Mbps.
 I think the answer is I don't thnk so.
Rgds,
Martin
This one
<http://www.cisco.com/web/partners/downloads/765/tools/quickreference/rou
terperformance.pdf>?  Last updated 2009, but the 7200 won't have changed
since then.
420 kpps and 215 Mbps, but that's 64-byte packets.  For an idealised
bimodal traffic distribution where half the packets are 64-bytes and the
other half are 1500 bytes you get 2.6 Gbps.
I don't think you'll find a 10G interface for a 7200 anyway, even if you
upgrade to an NPE-G2.
<http://www.cisco.com/c/en/us/products/routers/7200-series-routers/releva
nt-interfaces-and-modules.html>
Sam
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
Site Timeline
