Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Kenneth on February 25, 2008, 1:00 pm
Please log in for more thread options What does it meen when my ping reply is !.!.!.!.!.!.!. for one IP-address. In LAN the ping reply is !!!!!!!! but from another network only every other packet is comming back. | ||||||||||||||||||||||
Posted by headsetadapter.com on February 25, 2008, 1:20 pm
Please log in for more thread options Check for static route to non-existing or dead gateway. For example, if you have two static routes with the same metrics to the same destination, router will try to do a load-balancing between gateways, and if one is down, you will get every other packet lost. Good luck, Mike CCNP, CCDP, CCSP, Cisco Voice, MCSE W2K, MCSE+I, Security+, etc. CCIE R&S (in progress), CCIE Voice (in progress) ------ Headset Adapters for Cisco IP Phones www.ciscoheadsetadapter.com www.headsetadapter.com | ||||||||||||||||||||||
Posted by Gabriele Beltrame on February 25, 2008, 3:32 pm
Please log in for more thread options | Hi.
| | What does it meen when my ping reply is !.!.!.!.!.!.!. for one IP-address. | In LAN the ping reply is !!!!!!!! but from another network only every other | packet is comming back. | Hi, Apart from what already told in the previous reply, this behavior could be also caused by ICMP rate limiting Regards, Gabriele | ||||||||||||||||||||||
Posted by Trendkill on February 25, 2008, 3:46 pm
Please log in for more thread options > | Hi.
> | > | What does it meen when my ping reply is !.!.!.!.!.!.!. for one IP-address. > | In LAN the ping reply is !!!!!!!! but from another network only every > other > | packet is comming back. > | > > Hi, > > Apart from what already told in the previous reply, this behavior could be > also caused by ICMP rate limiting > > Regards, > Gabriele While unlikely, I have also seen this happen when there is load balancing across firewalls or similar devices and there is not a consistent rule set. Any time when load balancing takes place, there is this option, albeit mostly when you use statics or you have some kind of traffic manipulation device (load balancer, firewall, etc). | ||||||||||||||||||||||
| Similar Threads | Posted |
| 50% packet loss ? | February 25, 2008, 1:00 pm |
| some commands about loss packet | February 13, 2006, 8:33 am |
| WAN packet loss/latency | April 24, 2006, 9:23 pm |
| packet loss any work arounds | September 14, 2005, 12:01 pm |
| Cisco 2924XL Packet Loss? | January 2, 2006, 1:45 pm |
| Network traffic problem ---- packet loss | October 11, 2005, 11:01 pm |
| High Packet Loss with Catalyst 2950 | January 19, 2006, 11:03 am |
| packet loss through ipsec-tunnel after upgrade IOS | October 12, 2006, 4:49 pm |
| Cisco ASA: VPN behaviour when packet loss is high on WAN | April 17, 2007, 10:14 am |
| flow/packet loss through L3 C3560, pings OK | May 1, 2008, 12:59 am |
| %PIX-4-402106: Rec'd packet not an IPSEC packet. | August 25, 2006, 4:06 pm |
| At a loss | October 5, 2005, 6:30 am |
| Loss of VPN Access Using Pix 501 | July 21, 2006, 10:19 pm |
| Loss of outside dns after static command | November 25, 2005, 3:56 pm |
| Routing loss with mppp | March 17, 2007, 6:09 pm |
50% packet loss ?
Yahoo!
Windows Live
del.icio.us
digg
Netscape
