3750 which way to go ?
hi,
I have a cisco 3750 layer3 switch. I'm in very odd situation i use bgp on the switch with "desktop template". So far so good. Now the problem is that I want to use several (2-3) policy routing but this template dosent support it. I cant switch to "routing template" 'cause my arp usage (sh arp summary) is nearing 6000, but the routing template supports only 3000 !!
Does anyone tested what will happen if i switch to routing template with so many macs behind the switch ? will it go down ? Is there some solution to my problem ?!
raptor
