Can any describe a simple method to rate limit a fastethernet on a
3560 - I have seen and tried Police , srr queue commands but I have only been anle to achieve the desired rate limit on the inside of the port - it appears to still use the full bandwidth on its egress side.
service-policy output POLICY_5Mb police command is not supported for this interface The interface does not support the specified policy configuration and/ or parameter values. Warning: Assigning a policy map to the output side of an interface not supported
I am sharing Internet bandwidth between different people ...thanks
Thanks for the reply, I have made some progress: ! interface FastEthernet0/1 srr-queue bandwidth limit 10 service-policy input POLICY_5Mb !
- gives download 6.1Mbs upload 3.2 Mbs
When I try to setup a "10Mb" policy I appear to have a problem... ! interface FastEthernet0/2 srr-queue bandwidth limit 10 spanning-tree portfast service-policy input POLICY_10Mb !
- gives download 6.1Mbs upload 67Mbs
the config details are: ! class-map match-all CLASS_5Mb match access-group name ACL_5Mb class-map match-any CLASS_10mb match any class-map match-any CLASS_5mb match any class-map match-all CLASS_10Mb match access-group name ACL_10Mb ! ! policy-map POLICY_5Mb class CLASS_5Mb police 5000000 100000 exceed-action drop policy-map POLICY_10Mb class CLASS_10Mb police 10000000 100000 exceed-action drop ! Any apparent problem here? Thanks...
I've found that in real life, you have to adjust your burst size according to your traffic mix, and tweak things up and down based on actually measuring the traffic throughput.
Running through the theory is all grand, but to dial it in, you have to do some experimentation back and forth to get it to register the way you like..
I've also found the 4500/SupIVs or Vs to be much more forgiving for doing what you are trying to do.
I have spent a long time now trying various combinations of values to get my traffic shaping ploicies working but cannot crack it. To recap
- I want to slice up Internet Bandwidth between different ports on my switch; my first policy is: policy-map POLICY_5Mb class CLASS_5Mb police 5000000 100000 exceed-action drop
- I have this working on ! interface FastEthernet0/1 speed 10 srr-queue bandwidth limit 50 spanning-tree portfast service-policy input POLICY_5Mb ! and I get it working with upload speed of 3.2Mbs and download of
6.1Mbs - this is good and what I was looking for. However when I try to create a policy for 10Mb
policy-map POLICY_10Mb class CLASS_10Mb police 8000 8000 exceed-action drop ! ! interface FastEthernet0/2 speed 100 srr-queue bandwidth limit 10 spanning-tree portfast service-policy input POLICY_10Mb ! I get upload of 6Mbs but download of 61Mbs - so it appears to be using ALL the bandwidth. I have tried various settings for the "police command" ...... 8000 8000 to 10000000 10000000 - but theses never appear to impact the upload download rates achieved - am I missing something vital ? ! ! class-map match-all CLASS_5Mb match access-group name ACL_5Mb class-map match-all CLASS_10Mb match access-group name ACL_10Mb ! ! policy-map POLICY_5Mb class CLASS_5Mb police 5000000 100000 exceed-action drop policy-map POLICY_10Mb class CLASS_10Mb police 8000 8000 exceed-action drop ! ! interface FastEthernet0/1 speed 10 srr-queue bandwidth limit 50 spanning-tree portfast service-policy input POLICY_5Mb ! interface FastEthernet0/2 speed 100 srr-queue bandwidth limit 10 spanning-tree portfast service-policy input POLICY_10Mb !
I did some work on this years ago and have a config I will post. The idea was to prioritise outbound voice traffic into a DSL (likely
512kbps). Switch was 3560.
Of course the voice traffic was already DSCP marked and we just had to preserve the marking (by default the switch discards the marking) and then do queuing on the output.
The idea might have been to limit the non phone traffic (maybe to say 300kbps) leaving enough room for the voice or maybe to do output shaping on the switch of non voice traffic. Not sure which is configured here.
I cannot at present explain how it was supposed to work in detail since I forget - it was over 4 years ago.
The config is hopefully called Config-dscp-pass-through- WORKING-with---QOS-As-in-use--3560-2006-02-07
As I recall input queuing seems of no use to me. It's a plain switch L2 configuration, no routing.
Here are the bits that seem to matter:-
Some config elements are UNUSED but I have left them in in case it gives you any ideas. version 12.1
!! I dont think there are in use in the config !! but were part of earlier tests
class-map match-any CM-tointernet2 match input-interface FastEthernet0/2 class-map match-any CM-tointernet match access-group name ACL-tointernet class-map match-any CM-voice match any ! ! policy-map PM-tointernet2 class CM-tointernet trust dscp policy-map PM-tointernet class CM-tointernet trust dscp
interface FastEthernet0/6 description To Internet no ip address srr-queue bandwidth shape 25 60 0 0 srr-queue bandwidth limit 10 queue-set 2 priority-queue out no mdix auto
interface FastEthernet0/9 no ip address srr-queue bandwidth share 10 10 60 20 srr-queue bandwidth shape 10 0 0 0 mls qos trust device cisco-phone no mdix auto auto qos voip cisco-phone
interface FastEthernet0/14 no ip address srr-queue bandwidth share 10 10 60 20 srr-queue bandwidth shape 10 0 0 0 mls qos trust device cisco-phone no mdix auto auto qos voip cisco-phone
interface FastEthernet0/15 description IP Phone Port no ip address duplex full srr-queue bandwidth share 10 10 60 20 srr-queue bandwidth shape 10 0 0 0 mls qos trust device cisco-phone mls qos trust cos no mdix auto auto qos voip cisco-phone
