Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by vreyesii on October 11, 2006, 10:45 pm
Does anyone know if I can use a 3500 XL, and some how do a IOS upgrade or change a chip on the motherboard to make it a Layer 3 switch? Thank You, Victor | ||||||||||||||||
Posted by Walter Roberson on October 12, 2006, 1:43 am
Please log in for more thread options The documentation is pretty clear that they are layer 2 switches, so there wouldn't be anything supported. The 3500XL series uses the PowerPC403 processor; the 2900XL series uses the PowerPC403GA processor. Nothing else appears to use the same processor. If you were able to find a layer 3 device that used an -older- PowerPC model, you -might- be able to get somewhere (but I wouldn't expect much out of it.) I say "older" PowerPC model in that a newer PowerPC CPU might happen to have features that are not backwards compatible. | ||||||||||||||||
Posted by vreyesii on October 12, 2006, 10:15 am
Please log in for more thread options Thanks a lot for your help.
Victor On Oct 12, 1:43 am, rober...@hushmail.com (Walter Roberson) wrote: >
> >or change a chip on the motherboard to make it a Layer 3 switch?The > there wouldn't be anything supported.
> > The 3500XL series uses the PowerPC403 processor; the 2900XL series > uses the PowerPC403GA processor. Nothing else appears to use the same > processor. If you were able to find a layer 3 device that used > an -older- PowerPC model, you -might- be able to get somewhere > (but I wouldn't expect much out of it.) I say "older" PowerPC model > in that a newer PowerPC CPU might happen to have features that are > not backwards compatible. | ||||||||||||||||
| Similar Threads | Posted |
| 3500 XL switch | October 11, 2006, 10:45 pm |
| IOS 3500 switch | December 10, 2006, 12:05 pm |
| enable Span on Cisco Switch 3500 | October 16, 2006, 8:39 am |
| My Cisco Catalyst 3500 XL Switch is Dead ?!! | September 5, 2007, 2:45 pm |
| Traffic Shaping & Qos on 3500/3700 Switch tough one | August 18, 2006, 10:44 am |
| 2900 XL-EN vs 3500 XL-EN | June 13, 2007, 3:31 pm |
| SNMPv3 with Catalyst 3500 XL | August 30, 2005, 12:31 pm |
| 802.1q debugging on Catalyst 3500. | August 2, 2006, 9:04 am |
| 3500-XL Requirements for PVLAN | October 4, 2006, 4:48 am |
| Re: cisco 3500 series XL | April 12, 2007, 6:31 am |
| Runts between Catalyst 2950 and 3500? | August 31, 2005, 1:18 pm |
| Remove ALL configuration from a Catalyst 3500? | October 7, 2005, 7:06 am |
| port fast ? cisco 3500 xl | October 14, 2005, 8:16 am |
| Catalyst 3500 switching method | July 5, 2005, 11:56 am |
| enable 3500 snmp agent | March 20, 2009, 8:04 pm |
3500 XL switch
Yahoo!
Windows Live
del.icio.us
digg
Netscape
