Cisco Systems 2900 XL-EN vs 3500 XL-EN
Subject Author Date
2900 XL-EN vs 3500 XL-EN JF Mezei 06-13-07
Posted by JF Mezei on June 13, 2007, 3:31 pm
Due to lightning, I am looking at a replacement for a 2924 XL-EN switch.
If I were to get a 3525 XL -EN switch, is this just a more recent
version of the 2924 with , I assume, a faster processor ? ( the 3500
went out of sale in 2003 a couple years after 2900 series)
Are there features I would lose by going from 2900 to 3500 series switch?
Would I be able to just drop my config.text file into the 3500 and be up
and running ?
Posted by Doug McIntyre on June 13, 2007, 7:34 pm
Hmm, I seem to remember the 3524XL being out about the same time the 2924XL
was out. Although the 2924 (non XL) was out earlier..
You won't get a faster processor. The only difference between the two?
The 3524 has two GBIC slots on it. Otherwise, its identical.
No, its the same.
>and running ?
Sure, and your vlan.dat file too if you have any VLANs
setup. Otherwise, if you don't have that file backed up, you'll have
to do all that by hand again, or suck it down via VTP. Thanks cisco for
making that alot better in later switch hardware.
You'll gain GigabitEthernet 0/1 and GigabitEthernet 0/2 ports for your
config, but everything else will be identical, assuming you load
simular enough versions of IOS on it.
Posted by JF Mezei on June 13, 2007, 7:53 pm
Thanks for your quick reply.
Similar ThreadsPosted
2900 XL-EN vs 3500 XL-EN June 13, 2007, 3:31 pm
2900 XL switch February 8, 2005, 8:47 am
3500 XL switch October 11, 2006, 10:45 pm
IOS 3500 switch December 10, 2006, 12:05 pm
catalyst 2900 xl July 18, 2008, 7:35 am
Differences between 2950 adn 2900 February 8, 2005, 4:05 pm
SNMPv3 with Catalyst 3500 XL August 30, 2005, 12:31 pm
cisco 2900 vlans May 27, 2006, 3:56 pm
802.1q debugging on Catalyst 3500. August 2, 2006, 9:04 am
The 1900 and 2900 switches August 29, 2006, 11:49 pm
3500-XL Requirements for PVLAN October 4, 2006, 4:48 am
Re: cisco 3500 series XL April 12, 2007, 6:31 am
Updating 2900 switch September 26, 2007, 9:32 pm
Cisco Catalyst 2900 February 28, 2008, 12:47 pm
Runts between Catalyst 2950 and 3500? August 31, 2005, 1:18 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
