This seems like it should work okay I have 2 PIXs set up as follows PIX1: Inside: 10.0.0.1 Outside: 192.168.1.2
PIX1: Inside: 10.0.0.2 Outside2: 192.168.1.2
Inside ----PIX1-----Outside | ---------PIX2-----Outside2
They are both on the same Internal Network. Though the Outside ports are connected to different Physical Networks that have the same Address space. Both PIXs have the same Config (besides the Internal IP)
I've set up a Laptop on Outside2 with a Hosts file that has entries for Webservers that are published on the PIX2 Outside Interface mapped to the internal Webserver...
When I try to Access them it does not work...
Is having the same Outside Subnet confusing it? Seems like this would work?
Thanks, Scott
