Cisco Systems 1811 failure
Subject Author Date
1811 failure Jack 10-29-09
  `--> Re: 1811 failure Doug McIntyre10-29-09
Posted by Jack on October 29, 2009, 9:40 am
I have an 1811 that has gone sideways apparently - I pulled it off the
shelf and it will boot, but I can only gain access from the aux port.
When viewing from the console port, all I get are random ANSI
characters, but it does appear to be booting. I've tried to find a
good resource on how I can possibly reset the bootrom for this device
- is it even possible?
Posted by Jack on October 29, 2009, 10:30 am
As an addendum, every now and then I'll get this message on powerup:
System Bootstrap, Version 12.3(8r)YH6, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 2005 by cisco Systems, Inc.
Correcting the primary nv_flash
But other than that its ANSI characters...
Posted by Doug McIntyre on October 29, 2009, 12:30 pm
No, there isn't a way to reset the MON ROM system on any Cisco.
Sounds like it is corrupted beyond only the factory fixing it.
Smartnet would be your best bet assuming you are past your 90 days
initial warantee period.
CDW has the same Smartnet part at 3 different prices, probably pick
the cheapest one ($75)? As well as another dozen parts. Or another reseller.
Similar ThreadsPosted
1811 failure October 29, 2009, 9:40 am
sdm and 1811 July 14, 2006, 8:40 pm
1811 questions July 15, 2005, 11:17 pm
cisco 1811 June 1, 2006, 2:36 pm
Cisco 1811 August 7, 2006, 11:24 am
Problem with LAN->WAN on 1811 September 3, 2006, 5:21 pm
Question regarding the 1811 May 24, 2007, 7:48 am
cisco 1811 September 11, 2007, 11:33 pm
SDM problem on 1811 July 30, 2009, 8:06 am
Cisco 1811 configs May 9, 2006, 10:10 am
Cisco 1811: V.92 configuration November 29, 2005, 5:58 am
load balancing on 1811/k9 December 8, 2006, 12:45 am
1811 ipsec vpn's May 6, 2009, 9:55 pm
1811 default routes and ACLs June 16, 2006, 3:22 pm
Re: importing key and certificate into cisco 1811 August 30, 2006, 1:41 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
