ROM: System Bootstrap, Version 1
Provenir uptime is 2 hours, 56 m System returned to ROM by power- System image file is "flash:c184
Cisco 1841 (revision 7.0) with 1 Processor board ID FTX1138W1PM
2 FastEthernet interfaces
1 Serial interface WIC T1-DSU DRAM configuration is 64 bits wi
191K bytes of NVRAM.
31488K bytes of ATA CompactFlash
Configuration register is 0x2102
Building configuration...
Current configuration : 1373 bytes ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname Provenir ! boot-start-marker boot-end-marker ! enable secret 5 $1$8eLk$n.KaqmjMLycZcMxwCtuJu1 enable password ! no aaa new-model ! resource policy ! mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 ip subnet-zero ip cef ! ! no ip dhcp use vrf connected ip dhcp excluded-address 64.9.33.161 64.9.33.176 ip dhcp excluded-address 64.9.33.190 ! ip dhcp pool Provenir import all network 64.9.33.160 255.255.255.224 dns-server 4.2.2.1 4.2.2.2 default-router 64.9.103.33 lease 0 2 ! ! ip name-server 4.2.2.1 ip name-server 4.2.2.2 ip name-server 4.2.2.3 ! ! ! ! interface FastEthernet0/0 ip address 64.9.103.34 255.255.255.252 load-interval 30 speed 10 full-duplex keepalive 30 ! interface FastEthernet0/1 ip address 64.9.33.161 255.255.255.224 ip access-group sdm_fastethernet0/1_in in load-interval 30 speed 10 full-duplex keepalive 30 no mop enabled ! interface Serial0/0/0 no ip address shutdown ! ip classless ip route 0.0.0.0 0.0.0.0 64.9.103.33 permanent ! ip http server ! ip access-list extended sdm_fastethernet0/1_in remark SDM_ACL Category=1 remark PPTP permit ip any any ! ! control-plane ! ! line con 0 line aux 0 line vty 0 4
FastEthernet0/0 is up, line protocol is up Hardware is Gt96k FE, address is 001c.f6ff.8c2c (bia 001c.f6ff.8c2c) Internet address is 64.9.103.34/30 MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec, reliability 255/255, txload 4/255, rxload 3/255 Encapsulation ARPA, loopback not set Keepalive set (30 sec) Full-duplex, 10Mb/s, 100BaseTX/FX ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops:
0 Queueing strategy: fifo Output queue: 0/40 (size/max) 30 second input rate 134000 bits/sec, 34 packets/sec 30 second output rate 185000 bits/sec, 43 packets/sec 217277 packets input, 150525166 bytes Received 3 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog 0 input packets with dribble condition detected 215346 packets output, 90688952 bytes, 0 underruns 0 output errors, 0 collisions, 4 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out
