Got a problem I haven't had, but hopefully it's an easy one.
Client has a Cisco 1602 router. The startup-config is all set and correct. If we power off/on the router or reload, when it comes up the running config is empty -- it has nothing. At this point, we copy startup-config running-config, conf t and no shut the interfaces, and all is well...until it loses power or is reloaded for some reason.
Why would the unit not be taking the startup-config when it starts up? How would I fix that?
TIA....
