Will router run BGP
Threaded View
I am studying for the BSCI and i am wondering if BGP will run on a
Cisco 1700 series router with IOS version c1710-k9o3sy-mz.123-9.bin.
The reason that i ask is that i am having a hard time getting the
router synchronization working and everything looks correct. Thanks for
your help if you can lend it.
Re: Will router run BGP
Why wrote:
The decode is
c1710     - 1700 image
k9    - 3DES
o3    - Firewall/IDS
s    - Plus
y    - low end routing (poss no BGP)
mz     - runs from memory, zipped.
123-9     -  12.3(9)
Do you have access to the software advisor? The decode should let you look up
the features in the SW. The question I will leave you with is that there are
two contradictory letters there - y and s - restricted and plus. Which "wins"
as it it probably between these two if BGP is in or not...
Paul Matthews
Site Timeline
