hi there what terminal should i use to access my router from the console port ??
thanks
thanks
Teraterm is popular:
Hyperterminal comes free with Windows...but has problems depending on which version you have. You can get an updated version direct from Hilgraeve:
SecureCRT is much better than HyperTerminal, give it a try
