Well, that connects the two, but doesn't really give a WAN setup (as the OP was asking for). I'd get another router with a T1 card as well. Use a T1 cross over cable (Google it - lots of references) and you can create a P2P link between them. Then, you can have two separate lans and route between them.
Jim
