boson sim copied sh run and sh vtp
1912A#sh vtp VTP version: 1 Configuration revision: 0 Maximum VLANs supported locally: 1005 Number of existing VLANs: 8 VTP domain name : something VTP Password : cisco VTP operating mode : Server VTP pruning mode : Enabled VTP traps generation : Disabled Configuration last modified by: 0.0.0.0 at 00-00-0000 00:00:00
1912A#sh run Building configuration... Current configuration: ! ! vtp domain "something" vtp pruning enable ! vlan 2 name purchase vlan 3 name sales vlan 4 name marketing ! ! ! ! hostname "1912A" ! ! ! ! ip address 172.16.10.60 255.255.255.0 ip default-gateway 172.16.10.1 ! ! ! ! ! ! ! ! ! interface Ethernet0/1
vlan-membership static 2 ! interface Ethernet0/2
vlan-membership static 3 ! interface Ethernet0/3
vlan-membership static 4 ! interface Ethernet0/4
vlan-membership static 2 ! interface Ethernet0/5
vlan-membership static 3 ! interface Ethernet0/6
vlan-membership static 4 ! interface Ethernet0/7
vlan-membership static 2 ! interface Ethernet0/8
vlan-membership static 3 ! interface Ethernet0/9
vlan-membership static 4 ! interface Ethernet0/10
vlan-membership static 2 ! interface Ethernet0/11
vlan-membership static 3 ! interface Ethernet0/12
vlan-membership static 4 ! interface FastEthernet0/26
! ! trunk On ! interface FastEthernet0/27
! ! line console ! End
switch b
switchA is connect with switchB fa0/26--------------------fa0/27
Kindly help i want to know how will a host from a purchase vlan will connect to other switch (B)'s host which are in the purchse vlan.
Means
172.16.10.2> ping 172.16.10.16 and it should be successfull because they are in the same vlan
