VLAN clarification
Threaded View
Hello-I wanted to clear up a point-if different numbered VLANs on the
same switch are configured they still need a router to communicate-even
though they are on the same switch? I understand if the same VLAN is on
different switches they can all communicate without the need for a
Router?
TIA
Re: VLAN clarification
If they are on a Layer 2 switch, then yes they need a router to communicate.
If they are on a Layer 3 switch, then no they do not need a router to
communicate.
If you have multiple Layer 2 switches and they are trunked together, intra
VLAN communication will happen, ie VLAN 3 on switch 1 can talk to VLAN 3 on
switch 2 but the same as above appplies, they can not talk to other VLAN's
without some type of Layer 3 device.
Many thanks for that- i am on Semester 3 of CCNA and havent really
covered any Layer 3 switches-do you know if its in this course or is it
in CCNP?
One would think it is in there..... 80+% of the switch product line these
days is Layer3 capable switches.
Hi Gregg,
L3 switching is definately covered in the CCNP, particularly the BCMSN
course.
When I took the CCNA around July this year, I didn't learn any L3
topics for the exam and I can't recall any questions on it. Intervlan
routing was carried out by external routers. I'd check the CCNA
blueprint to be sure though.
Thanks guys-will do
They do, but the L3 switch is that router.
P.
Paul Matthews
paul@cattytown.me.uk
http://www.hepcats.co.uk
That is the whole point of a VLAN - keep things separate.
Only if someone has fucked up the config.
Paul Matthews
Site Timeline
