- Vote on answer
- posted
19 years ago
I've got a bit of a blindspot here. One can configure a serial interface as an asynch interface with the command "physical-layer asynch", but when you do which line number is in control of the physical attributes of the line? Eg serial 0/1, which line number would one use to set the speed etc?
Yours confused, Paul
You should be able to see that using 'show line' command.
Hi Paul,
Congrats on passing the test!
"To map the interface number to a line number, first multiply the slot number by 32, then add the unit number, and add 1: line number = ( *
32) + + 1."int serial0/1 physical-layer async no shut
line async 2 stopbits 1 flowcontrol hardware transport input all modem inout speed 115200 no shut
int loopback 1 address a.b.c.d /32
telnet a.b.c.d 2002
----- Original Message ----- From: John Smith Newsgroups: alt.certification.cisco Sent: Tuesday, March 22, 2005 8:49 AM Subject: Re: using "physical-layer asynch" on serial interfaces
sounds like our tests were very similair! i'm not sure why but I did pick line 1, (maybe I saw it in sh run), but at the end I did a sh line and next to line 1 it mentioned serial0/0, so i was fairly happy I got the correct one. Even after setting the loopback interface I couldn't reverse telnet to the modem though, and I can't work out what I've got wrong for that to fail. I had the usual
stopbits 1 modem inout transport input all
still, i passed the exam, it would be nice to understand why serial0/0 becomes line 1, is there a rule behind it?
Hi Owen, thanks!
Yes that looks pretty similair to what I did. Maybe I forgot a "no shut". Ah well, not to worry.
Regards Paul
and thanks for letting me know the rule - appreciated.
