USB to RJ-45 console cable?
Threaded View
Hi All,
I know have read numerous threads on Google goups and cannot
come up with an answer on this one.
I have already read and seen that there are cables/adapters that
go from USB to DB-9. That would allow you to connect your standard
serial console cable as you normall would. I am trying to find a way
to eliminate this.
I would like to buy/make a cable that will have a  USB connector on
one end and an RJ-45 on the other. I'm not sure if it is as easy as
cutting off a connector on the usb and just terminating the RX/TX/GND
like you can do with a serial cable (DB-9).
I know there may be some issues with going from USB to rs-232
signaling and I could always build some kind of breakout box
in the middle.
Any thought?????
- Jay
Re: USB to RJ-45 console cable?
Hi there,
I have the Keyspan Serial to USB adapter, converting RS-232 to USB. I use it
everyday to connect to my Cisco routers. Works very good without any flaws. /
Site Timeline
