hi, i will be getting some routers and/or L3 switches. I will practice on some simulators fiorst though, so I nkow whati 'm buying. At the mopment I really know very little, oter than what a router is(which I learnt recently!).
I am thinking of getting a 2611
but currently, i see some good offers. Like a 1*2503, and 2*2501, and a switch, for £250
And, a few 1603 routers for £50 though apparently 2500s are better for CCNA, they include allowing me to configure BGP, and perhaps other routing protocols that aren't supported by 1600 series.
- It notice that some of these routers, liek maybe the 2501, only have 1 ethernet port (is there a good site with specs and pics)? I don't think a router with one ethernet port is useful for practicing with.
And, I heard that it's improtant to be able to connect routers 'back to back' what do i look for in order for a router to have this facility?
how much should i be looking to spend? how many ruotesr should i be getting, should i mix and match like a 2600 with a 2501. e.t.c. I really don't know at all
thanks.
