You may wish to investigate Cisco's IOS Software Selector:
Brad Reese BradReese.Com Cisco Certified Network Engineer Jobs Toll Free: 877-549-2680 International: 828-277-7272 Website:
I have two questions about the IOS's.
Thanks.
Yes.
I'm sure 2 seconds at your favourite search engine can.
Ish. The normal version have ACL options which will act as a packet filter if that's what you want. If you get an IOS with the Firewall feature set then you also get things like Context Based Access Control, Intrusion detection etc.
You need an IOS that has the Firewall feature set.
I'm not sure I understand the question. A large part of the configuration is similar but there are significant underlying differences.
Jim
