I've setup a trunk between a Cat 5000 and a Cat 3550. The trunk negotiated as ISL and seems to be up fine. The 3550 is in server mode and the 5000 in client mode. I've verified that the 3550 has the higher revision number. The problem is the configured VLANs on the 3550 are never getting to the
5000. I can't seem to find any problem with the config. I'm sure it's something I'm overlooking. I've also verified the VTP domain name matches and neither has a password.Thanks in advance,
Mikey
