Throughput: Limited on Pix 506
Hello all,
I don't know if this is the good place for this question. If not, please tell where to post.
I actually own a Pix 506E. I want to buy another one in case of crash of the first one. The idea is to save the config of the fisrt one and if there is a crash, I replace it with de second one where I restore config.
I saw on an online store a Pix 506 (not E). In the product description, there is copy/past of the 'show ver' command. I used it to compare to mine.
On my Pix, I can read Throughput: unlimited but on the store's one, I can read Throughput: Limited.
I can't understand what is limited and if this limitation will make not possible what I project to do (replace one by the second with config restore)
Hre is the complete show ver on my actual Pix: Result of firewall command: "show version"
Cisco PIX Firewall Version 6.3(4) Cisco PIX Device Manager Version 3.0(2) Compiled on Fri 02-Jul-04 00:07 by morlee pix.centralweb up 91 days 1 hour Hardware: PIX-506E, 32 MB RAM, CPU Pentium II 300 MHz Flash E28F640J3 @ 0x300, 8MB BIOS Flash AM29F400B @ 0xfffd8000, 32KB
0: ethernet0: address is 0014.1cd2.2516, irq 10 1: ethernet1: address is 0014.1cd2.2517, irq 11 Licensed Features: Failover: Disabled VPN-DES: Enabled VPN-3DES-AES: Enabled Maximum Physical Interfaces: 2 Maximum Interfaces: 2 Cut-through Proxy: Enabled Guards: Enabled URL-filtering: Enabled Inside Hosts: Unlimited Throughput: Unlimited IKE peers: Unlimited This PIX has a Restricted (R) license.
Here is the result of the show ver on the one I plan to buy: Cisco PIX Firewall Version 6.3(5) Cisco PIX Device Manager Version 3.0(4)
pixfirewall up 5 mins 50 secs
Hardware: PIX-506, 32 MB RAM, CPU Pentium 200 MHz Flash i28F640J5 @ 0x300, 8MB BIOS Flash AT29C257 @ 0xfffd8000, 32KB
0: ethernet0: address is 0050.54ff.be5b, irq 11 1: ethernet1: address is 0050.54ff.be5c, irq 10 Licensed Features: Failover: Disabled VPN-DES: Enabled VPN-3DES-AES: Enabled Maximum Physical Interfaces: 2 Maximum Interfaces: 2 Cut-through Proxy: Enabled Guards: Enabled URL-filtering: Enabled Inside Hosts: Unlimited Throughput: Limited IKE peers: Unlimited
Thank you a lot for your help
Chris
Christophe Pin
