I have a 2509 connecting across the octal cable to console inputs using revese telnet on loopback 0 at 192.168.11.11. Everything works so far. I can log into the other routers.
When I log into the 2509 from a PC using telnet ( ip telnet ) to the 2509 eth0 at 192.168.10.9, I am able to log in.
But if I then try to reverse telnet to the console inputs of the other routers, I get an error:
Trying r1 (192.168.11.11, 2001)... % Connection refused by remote host Trying r1 (0.0.0.0, 2001)... %invalid host address
The con 0 session to the 2509 is able to reverse telnet to the lines 1-8 configured for transport input telnet, but the telnet session to eth0 is not.
Is there a way to do this ? If so, how ?
Thanks a million, Joe
