Telnet into router from the web..
Threaded View
i have a 2503 router.. for my ccna ..
i want to be able to access this router from the web.. so i can practice ios
commands from work..
i have a belkin wireless router with 5 port switch.. my broadband connection
is going into the belkin router.
my main pc is going to port 1 of the belkin and e0 of the router is going
into port 2.  my main pc gets its ip address from the dhcp from the belkin
router.. i have manually configured the IP of e0 on the cisco router .. to
the same network as the belkin router..
i can telnet from my main pc into the cisco router.. using the private ip
address..
however i want to be able to telnet in to my router from work.. can someone
give me some advice on this please?
i have opened the ports on my belkin router..
thanks
Re: Telnet into router from the web..
You'll probably have to telnet to your pc first (using remote desktop, pc
anywhere) and then from pc to cisco. That's how i used to do it.
There might be another way but i'm not familiar with it.
You can try configuring extended access list on the cisco to permit your
work ip on eth0 of your cisco through telnet port 23. I don't know if that
would work but doesn't hurt to try it.
Good luck
im only on semester2 .. so im not that advanced yet :)
i'll have a look at the remote desktop method..
thanks
You need to configure port re-direction on the belkin. Point port 23 to
the address of the 2503 and you're done.
You'll also need to configure your terminal lines on your Cisco router
with a password and login statement or else you won't be able to login
via telnet.
i dont think my belkin has that facility..
i have setup the telnet passwords..
What is the model number of the Belkin router you're using? You should
be able to get the manual for it from the vendor web site and confirm
this. Many times, it's just a matter of upgrading the firmware/software
revision to support any new features. If it doesn't support this feature
  as is, check for a firmware upgrade.
Site Timeline
