remember when we write masks as /21 or /24 what we are saing is "the first 21 (or 24) bits represent the network. You had done the "hard" bit going to binary and spotting the pattern. That's five bits the same here, added to the first two octets 8+8+5=21.
The thing about subnetting and summarisation is that it is NOT difficult. Some people struggle, unfortunately some people that teach struggle. The people they teach then struggle and so on, and we have lots of people struggling.
You can only summarized in multiples of 2's (2,4,8,16....), so the first
64 networks (0...63) is 2**6, leaving 10 (16 -6) as your netmask. Same goes for the next 32 networks (64..95), 2**5 = 32; 16 -5 is 11. The next group of 4 networks (96,97,98,99) is 2**2, 16 -2 is 14; leaving 10.100.0.0 by itself which is /16. BTW, 10.100.0.0/14 would include 10.101.x.x to
10.103.x.x also.
2**2 is 2 to the power of 2. 10.100.0.0/14 means it has 14 bit netmask (8 in the first octet plus 6 in the second octet. Thus the second octet has
6 bits in the network field and 2 bits in the host field. 2**2 = 4, so that means 4 hosts starting with 100 (100, 101, 102 & 103).
I think in a thread like this, it helps when posts don't disappear. Google says that yours will vanish in 3 days. People do google and for old threads like this you know If you are so worried about privacy, post anonymously!
He over-summarized. 10.0.0.0/9 is 10.0.0.0 netmask 255.128.0.0 and it covered 128 subets 10.0.0.0/16 through 10.127.0.0/16. The question only asked to summerize to 100.
If you didn't see that I was getting at your posts disappearing from google's archive, then the rest of your response may not be relevant.
I never suggested you not posting to a NG. Of course I'm in favour of everybody benefiting from answers. That is why I think it's important to keep the post in the archive.
I didn't ask any question - cerainly not one that required help.
Though if you're referring to my question as to why you set your posts to disapepar from google's archive, I imagine that you really should be able to answer it better than others.
I didn't complain about you not answering. And I didn't complain about you not answering adequately. I'm glad you answered and i'm sure the answer is good. And I never said you were obligated to answer.
you defend that you answer, you defend that you don't answer. It sounds like you weren't sure what I was getting at and wanted to cover all possibilities. You should've just considered what I meant!! I can't have been any less difficult to understand than one of the books or routers you used for your CCIE!!! ;-)
