In a class C subnet of 255.255.255.240 are not host xxx.xxx.xxx.001 to xxx.xxx.xxx.15 invalid? Arnt the first eligable hosts xxx.xxx.xxx.017/28 to xxx.xxx.xxx.030/28?
thanks Steve C.
thanks Steve C.
That depends upon whether you are running classful or classless routing. If running classless, it also depends upon whether or not you have the 'ip subnet-zero' option enabled. If running classful, not.
Also, with that subnet mask, .15 would be a broadcast address and cannot be used for a host address.
Fred
So, if I were running Rip V2, EIGRP or OSPF, I could have a 198.142.26.2/28 address?
Steve, great question. If you are studying for the Cisco CCNA exam, then yes, they are now valid. Pre- 2005 exams would have considered those invalid. As the other posts mention, this is the ip subnet-zero command, which is on by default starting in IOS version 12.1. Cheers! Todd Lammle
Yes, if the ip subnet-zero feature was enabled.
Type it at the global configuration prompt.
Fred
And that is why I check this news group every day! THANKS ALL. Now back to the books.
