- Vote on answer
- posted
18 years ago
Stub/Passive in OSPF
- Vote on answer
- posted
18 years ago
I don't see a correct answer.
Doan
- Vote on answer
- posted
18 years ago
Although area 1 as NSSA reduces LSA traffic from area 0 (doesn't completely eliminate it) it also provides for another router on the Ethernet segment acting as ASBR to pass redistributed routes from another AS/domain as LSA 7 traffic back to area 0 as LSA 5 traffic, choice C may not reduce overall routing protocol traffic through the interface as desired.
Robert
- Vote on answer
- posted
18 years ago
I'm thinking D works assuming that even though the Ethernet network is a passive interface,network 192.168.12.0 0.0.0.255 area 1 is still advertised in Area 0 via the serial interface while no hellos or LSAs are sent out via the Ethernet.interface.
Robert
- posted
18 years ago
Your OSPF router has one serial interface, and one Ethernet LAN interface. The subinterface is configured in the following manner:
interface serial 0.122 point-to-point
ip address 192.168.1.1 255.255.255.0
encapsulation frame-relay
frame-relay interface-dlci 122
Your want to allow hosts on your LAN to send and receive data, but you don.t want routing traffic to go through that interface. Which of the following commands should you use to complete your configuration?
A. interface serial 0.122 point-to-point
passive-interface ethernet 0
B. interface ethernet 0
ip address 192.168.12.1 255.255.255.0
passive-interface
C. router ospf 172
area 1 nssa
network 192.168.1.0 0.0.0.255 area 0
D. router ospf 172
- Vote on answer
- posted
18 years ago
why not C?
- Vote on answer
- posted
18 years ago
Ok, thanks!
Doan
