Hi! I have some problems with solving skill exam. can somebody help me?
So scheme goes something like this - we have 3 routers, one is headquater office named GAD, and branch offices routers are Boaz and Aniston. There are switches, one on Aniston one on Boaz and we have managment and production host one one switch and management and production switch on the other host. The exam goes like this ---
Circle one Location Anniston or Boaz
Circle one Version 1
The wan IP network address is 192.168.1.0 Boaz, 192.168.101.0 Aniston with subnet mask of 255.255.255.0
The local Lan has been assigned an IP network address of 172.31.0.0
Each subnet of the above network needs to accomodate 3000 host addresses. Use the 2 usable subnet for the LAN. Do not use subnet zero as the first subnet. The IGRP AS nubmer is 1.
Basic planning Using the chart below, plan the first 10 usable subnets of the lan network address, that was provided by the instructor
Subnet subnet adress subnet mask first host last host broadcast
0 Do not use subnet 0 1 2 3 4 5 6 . . The wan interface of GAD is assigned to lowest usable adress in the subnetwork Identify and use the second lowest usable wan address for the S0, or S0/0, interface of the assigned router __________________. For security reasons, the IP addresses of the assigned subnet are split in two groups. The production workstations will be assigned the lower half of the ip addresses. The network devices and management stations will be assigned the upper half of the ip addressese. The ethernet router interface is to be assigned the highest usable address. Identify the required IP address of the Ethernet interface on the assigned router. _______________________(based on exam version number and subnet assignment)The host configurations must also be planned. Using the chart below complete the host information.
Branch: IP adress range Anniston or Boaz
Production host range (lower half)
Management host range (upper half)
Production host Ip address Subnet mask Defaut gateway
Management host IP address Subnet mask Default Gateway
Step 2: Security planning There are several security concerns in the internetwork. Develop Access control lists (ACLs) to address security issues. The following are the concerns:
- The company has an Intranet Web server host that all systems can reach at IP address 172.16.0.1 with only HTTP access. No other protocols will be permitted to this site.
- The company also has a server pool in the 209.0.0.0/24 network. The server pool addresses are divided in half. The servers in the upper half of the address range are reachable only by managent hosts using all possible IP protocols. The servers in the lower half of the address range are reachable by all LAN hosts using all possible IP protocols. The servers should not be accessible by any other hosts.
- The company has discovered an Internet Web server at 198.0.0.1 that is known to contain viruses. All hosts are to be banned from reaching this site.
- All other traffic should be permited to any destination
These security requirements should be accomplished with a single access list. Plan the access list required to accomplish these tasks, to which interface this will be applied, and the direction the list will be applied.
Place the ACL plan information below.
Step 3: Cabling Now that the planning process is complete, it is the time to construct the physical layer. Using the diagram, connect all the associated hardware for the local branch. Step 4 Basic configuration Apply a basic configuration to the router. This configuration should include all the normal configuration items. These items include but are not limited to router name, passwords, interface descriptions, routing, host table, and a banner to be displayed before login.
The managment workstation and the production workstation should also be configured with the appropriate information.
Step 5 Security configuration After basic functionality is in place, security needs to be added to the configuration. Using the security requirement and planning from previous steps, implement and test these basic security functions.
Step 6 Troubleshooting Now that everything is successfully configured , the instructor will introduce some problems. Tha steps and commands used to correct these issues must be documented. The show running-config command should be used as a last resort.
Symptom/cause Commands/Results Detailed Solutions Initials
thanks
