Firstly, Im new to all this !
I just got my cisco lab consisting of:-
1 * Cisco 1605 router with WIC1T installed 1 * Cisco 1601 Router 1 * Cisco 2908XL SwitchI got the 1605 as it has 2 ethernet ports, as I plan to run my dsl through it. I have no Idea what the best way of getting all this working is. I figured that getting dhcp on interface ethernet1 on the
1605 would be a good place to start. DSL would be on ether0 from my modem.I have the 1605 connected to the one of the ports on the switch and my laptop in a different port on the switch. Im not getting any kind of dhcp and cant even ping the router when I manually set the ip on the laptop to the next ip above the routers.
Here is my config:-
cisco1605#sh conf Using 1086 out of 7506 bytes ! version 12.2 service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname cisco1605 ! enable secret 5 $1$l7iK$k2pWJZE0tCVCzTVlvYsDi1 ! ip subnet-zero no ip domain-lookup no ip dhcp conflict logging ip dhcp excluded-address 192.168.1.0 192.168.1.101 ! ip dhcp pool home network 192.168.1.0 255.255.255.0 domain-name home.com dns-server 212.23.8.1 212.23.8.6 default-router 192.168.1.50 lease 7 ! ! ! ! interface Ethernet0 description connected to Internet ip address 10.0.0.1 255.255.255.0 shutdown ! interface Ethernet1 description connected to EthernetLAN ip address 192.168.1.50 255.255.255.0 ! interface Serial0 description connected to Router ip address 192.168.0.11 255.255.255.0 encapsulation ppp ! router rip version 2 passive-interface Ethernet0 network 192.168.0.0 network 192.168.2.0 no auto-summary ! ip classless ip route 0.0.0.0 0.0.0.0 Ethernet0 no ip http server ! snmp-server community public RO ! line con 0 exec-timeout 0 0
