I think that I'm having a problem with the serial interface. Here is the scenario, I have 3 cisco 2500 routers (2503, 2501, 2514). I'm trying to connect the router in a simple lab with the 2503 being in the middle connecting the 2501 via Serial 1 and the 2514 via Serial 0. From the 2514 I can ping the serial S0 of the 2503 router and vice versa. But I can't get the S1 interface to come up. It is always saying manually down after I run a "sh ip int brief", I've reloaded the routers, and swapped cables and still get the same result. I have clocking enabled on the interface since both interfaces are the DCE to the other two routers. When I do a sh cont serial 0 I see the cable as a V.35 but I'm using the standard back-to-back serial cable?? Is this weird?? Do you think it could be a bad interface?? Are there any other troubleshooting methods or diagnostics??? I have the config below, I threw RIP on the routers to see if they would communicate and populate the tables but they still wouldn't, possibly because they aren't learning because of the downed interface. If you want to see the other configs I can place them in here two. Any help will be appreciated, this is driving me crazy!!!
Thanks
version 12.1 no service single-slot-reload-enable service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname 2503 ! no logging console ! ! ! ip subnet-zero no ip domain-lookup ! ! ! ! nterface Ethernet0 ip address 192.168.3.1 255.255.255.0 ! interface Serial0 description DCE connection to 2514 ip address 192.168.1.1 255.255.255.0 no fair-queue clockrate 64000 ! interface Serial1 description DCE connection to router 2501 ip address 192.168.2.1 255.255.255.0 no fair-queue clockrate 64000 ! interface BRI0 no ip address shutdown ! router rip network 192.168.1.0 network 192.168.2.0 network 192.168.3.0 ! ip classless ip http server ! banner motd ^CC This is the 2503 router^C ! line con 0 line aux 0 line vty 0 4 login ! end
2503#sh ip int brief Interface IP-Address OK? Method Status Prot ocol BRI0 unassigned YES NVRAM administratively down downBRI0:1 unassigned YES unset administratively down down
BRI0:2 unassigned YES unset administratively down down
Ethernet0 192.168.3.1 YES NVRAM up down
Serial0 192.168.1.1 YES NVRAM up up
Serial1 192.168.2.1 YES NVRAM down down
