Now with pictures!
Re: serial cable
If you have one cable to connect routers back-to-back, you don't have to put
anything between. One router, where you have DCE end of cable connected,
should provide clocking for the serial link. If you not sure, which end is
which, check the output of the "show controller serial X/X" command on both
routers. One end should say DTE, and another DCE. Then issue "clock rate
XXXXX" on the DCE end.
Good luck,
Mike
Cisco IP Phone Headset Adapters
www.headsetadapter.com
Good luck,
Mike
Re: serial cable
the reason I dont want a single (crossover) cable, as the one you refer to,
is
that I see it as a learning exercise (I am doing CCNA), and I was opting for
the
more "realistic" option, with real cables that could (but won't) be plugged
into some real DCE.
So you just plug the two V.35 ends together (I am assuming one is male
and one is female), is that correct ?
(I haven't bought any cables yet)
dik
Re: serial cable
Thanks,
I have one follow-up question:
When, in your lab, you connect a DTE and a DCE cable together, does it
matter what cables you use, e.g. will two X.21 or two EIA/TIA-449 (or 232)
or two EIA-530 work just as well as the two V.35, and will you have to
configure differently depending on which you use ? I believe the 232 is
asynchronous, presumably you will have to set something to "async" in IOS ?
dik
dik
Re: serial cable
Simple put... different serial cables give you possibly different "speeds".
e.g. With a V.24 you could have 768Kbps synch while with a V.35 you could
have 8Mbps synch.
You can even use the console cable to interconnect two routers using AUX
ports ( up to 128Kbps )
Regards,
Gabriele
have 8Mbps synch.
Regards,
Gabriele
Re: serial cable
In "real life" you never configure DTE/DCE modems. In most cases you have
preconfigured unit, you connect to the router by DB-60 V.35 cable. Or, with
new network modules, you just plug RJ-48 (same size as RJ-45 cable) into
your router. So, connecting routers back-to-back by DTE-DCE cable or by T1
cross-over cable IS a "real life" unless you work for ISP as Telco
technician.
Theoretically, if you want to spend an extra couple hundreds dollars, you
can get DTE/DCE modems, but all you will get is a couple "black boxes" to
simulate exactly the same scenario as you have with single back-to-back
cable. Plus, for CCNA, CCNP or even CCIE, it does not matter, *how*
physically devices are connected. The matter is that devices ARE connected.
Good luck,
Mike
www.ciscoheadsetadapter.com
Re: serial cable
hi,
from my understanding of routers i am going to state the obvious,
just in case u havent tried it. u know that at default serial
interfaces are shutdown. you will first have to bring the interfaces up
on both routers. then configure the dce router with a clock rate of
56000. b4 this u must give each interface an ip address.
ping the other router if youget a reply then your connection is good .i
hope i have been of help
Richard Sole wrote:
Site Timeline
- » Making The Pirate Bay obsolete
- — Next thread in » Cisco Certification
- » ISL and 802.1q difference?
- — Previous thread in » Cisco Certification
- » digital printing|custom printed packaging |computerized cutting services.
- — Newest thread in » Cisco Certification
- » Caller ID stumper [telecom]
- — The site's Newest Thread. Posted in » General Telecommunications Forum
- » 5 things to consider before buying Explosion Proof Camera
- — The site's Last Updated Thread. Posted in » General Home Automation
