routing - once again
Threaded View
Hello
Once again i have question about routing:
--network1---Router1----Router2---network2
RIP protocol used. Normally Router2 sends updates to
Router1: network2, metrics=1.
Case1: network2 is disconnected, i DO NOT use route poisoning, and i do
not use split horizon. How does that update from Router2 to Router1 looks
like ?
After that how does update from Router1 to Router2 looks like ?
Case2: network2 is disconnected, i DO use route poisoning, and i do not
use split horizon. How does that update from Router2 to Router1 looks like
Thanx
Michal
Re: routing - once again
Route poisoning and split-horizon are used to prevent loops.  You don't
have any possible loop in your example so it doesn't matter!
Doan
On Tue, 24 May 2005, vertigo wrote:
it does matter - because i still do not understeand what is the difference
between systems with and without router poisoning, what is the difference
between sending data with metric 16 and not sending data - they both can be
interpreted in the same way - network is down. So what route poisoning is
really for ? For me it only makes convergence faster...
If somebody could resolve these two Cases below, maybe i could
understeand it finally.
Thanx for the patience and help :)
On Wed, 25 May 2005, vertigo wrote:
Ok. My mistakes, under some circumstances routing loop can still
happenned.  Let's work this out and see what would happenned.
Let's start from the beginning.  At t1, the routing table of Router1 &
Router2 looks  like this:
R1:
network1 - connected
R2:
network2 - connected
Now, at t2 update, both routers exchange the whole routing table:
R1:
network2 - Via R2 - 1 hop
R2:
network1 - Via R1 - 1 hop
the network has converged at this point.
Now, Normally R2 will send an update to R1 announcing network2 is down and
they both converged to:
R1:
R2:
network1 - via R1 - 1 hop.
But what would happenned if, for some reasons, R1 didn't receive this
update?  R1 still has the old information:
R1:
and at the next update, send this information back to R2 (no
split-horizon).  R2 now has:
R2:
network2 - Via R1 - 2 hops
and at the next update, R2 now send this information back to R1 (again
because of no split-horizon).  R1 now has:
R1:
network2 - Via R2 - 3 hops
and at the next update, R1 now send this information back to R2.
R2:
network2 - Via R1 - 4 hops
As you can see, without split-horizon, a routing loop has occurred. With
RIP, this stops when the hop-count for network2 reached 16 (counting to
infinity), which is another feature to stop routing loops.
Route poisoning or poisoned reverse, R1 will advertise back to Router2
that it can reach network2 with hop-count of 16 (infinity) and stop
the loop faster.
Hope this helps.
Doan
Site Timeline
