I want to setup vlan routing for a test lab at home and found that none of the routers I have at the moment support encapsulation on the Ethernet port. I suspect this is because they are Ethernet and not fast Ethernet?
Anyone out there who can make a suggestion to which router would be best but I`m not after the all singing all dancing variety as I`m on a tight budget
Thanks
Gordon
