Now with pictures!
Subject
- Posted on
Router problem
- 02-23-2009
February 23, 2009, 10:02 am
I have set up 2 cisco 2600 routers. interface 0/0's are conncted with
a crossover cable to simulate Wan. and interface 0/1 has a laptop on
each side.
the problem is when i ping Laptop 1 from Laptop 2 the ping woks only
for about 5 minutes, and then stops for no reason that i can see, if i
refresh the access list (take off and then apply it again) ping starts
again for another 5 minutes, i have tried 2 other routers and the same
issue occurs.can anyone shed any light on this?
Router 1
ip subnet-zero
no ip dhcp-client network-discovery
call rsvp-sync
config t
interface Ethernet0/0
ip address 192.168.10.1 255.255.255.0
no ip mroute-cache
full-duplex
no mop enabled
interface Ethernet0/1
ip address 192.168.1.254 255.255.255.0
no ip mroute-cache
full-duplex
router rip
network 192.168.1.0
network 192.168.2.0
network 192.168.10.0
ip default-gateway 192.168.10.1
ip classless
ip http server
logging 192.168.1.1
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
password ****
login
end
Router 2
ip dhcp pool Router2
network 192.168.2.0 255.255.255.0
default-router 192.168.2.254
domain-name Router2.local
netbios-name-server 192.168.1.1 255.255.255.0
dns-server 192.168.1.1
ip address 192.168.10.2 255.255.255.0
ip access-group Router2_Access in
full-duplex
no mop enabled
ip address 192.168.2.254 255.255.255.0
full-duplex
router rip
network 192.168.1.0
network 192.168.2.0
network 192.168.20.0
ip default-gateway 192.168.10.2
ip classless
ip http server
ip pim bidir-enable
ip access-list extended Router2_Access
permit ip any host 192.168.1.1
permit ip any host 192.168.1.2
permit ip any host 192.168.1.8
permit ip any host 192.168.1.15
permit ip any host 192.168.1.45
permit ip host 192.168.1.1 any
ip access-list extended Router2_Access2
permit ip any any
snmp-server community public RO
line con 0
line aux 0
line vty 0 4
password ****
login
end
each side.
Router 1
ip subnet-zero
call rsvp-sync
config t
no ip mroute-cache
full-duplex
no mop enabled
no ip mroute-cache
full-duplex
router rip
network 192.168.1.0
network 192.168.2.0
ip classless
ip http server
logging 192.168.1.1
line con 0
line aux 0
line vty 0 4
password ****
login
end
Router 2
full-duplex
no mop enabled
full-duplex
router rip
network 192.168.1.0
network 192.168.2.0
ip classless
ip http server
ip pim bidir-enable
permit ip any any
line con 0
line aux 0
line vty 0 4
password ****
login
end
Re: Router problem
RIP updates are not allowed to pass by the ACL. After some time the route is
removed from the RIB.
Regards,
Gabriele
| each side.
| Router 1
| ip subnet-zero
| call rsvp-sync
| config t
| no ip mroute-cache
| full-duplex
| no mop enabled
| no ip mroute-cache
| full-duplex
| router rip
| network 192.168.1.0
| network 192.168.2.0
| ip classless
| ip http server
| logging 192.168.1.1
| line con 0
| line aux 0
| line vty 0 4
| password ****
| login
| end
| Router 2
| full-duplex
| no mop enabled
| full-duplex
| router rip
| network 192.168.1.0
| network 192.168.2.0
| ip classless
| ip http server
| ip pim bidir-enable
| permit ip any any
| line con 0
| line aux 0
| line vty 0 4
| password ****
| login
| end
Re: Router problem
He is talking about IP permit statements. However, I would think that
it might actually be interface speed or physical layer (bad cable or
connection). Try hard-setting the ports both speed and duplex. Look
for interface errors to confirm (sho int) .
Hope this helps.
Robert.
Site Timeline
- » Making The Pirate Bay obsolete
- — Next thread in » Cisco Certification
- » Is used Cisco equipment safe to buy?
- — Previous thread in » Cisco Certification
- » iPhone SUPER 80% discounts
- — Newest thread in » Cisco Certification
- » Helper Woes
- — The site's Newest Thread. Posted in » CCTV, Alarms and other Physical Security
