Now with pictures!
Subject
- Posted on
router help needed ....urgent
- 06-30-2007
June 30, 2007, 6:46 pm
Hi Techies....
I'm stuck in a problem....as i'm not very well with cisco routers...
I have a cisco router 1800 series with a 4 port fast ethernet card.
now i have attached both the internet isp's (A and B) over ethernet to
this router, now what i need is that all my traffic for internet from
lan A (192.168.1.0/24) should be routed to isp A and all from lan B
(10.220.16.0/24)should be routed to isp B.
Please ckick the link for the diagram.
http://img248.imageshack.us/my.php?image=drawing1jq5.jpg
Thanks..............
Re: router help needed ....urgent - Part 1 - Basic Config
Here is your basic config (part 1 of 2):
no service pad
no service config
no service finger
no service tcp-small-servers
no service udp-small-servers
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname [router name]
no aaa new-model
enable secret [enable mode password]
no enable password
clock timezone [timezone name] [timezone offset]
clock summer-time EST recurring 2 Sun Mar 2:00 2 Sun Nov 2:00
ip subnet-zero
no ip source-route
no ip domain-lookup
ip domain-name [anything resembling your Internet domain name]
interface FastEthernet1/0
description *** Inside Network - LAN A ***
ip address 192.168.1.254 255.255.255.0
ip nat inside
speed auto
interface FastEthernet1/1
description *** Inside Network - LAN B ***
ip address 10.220.16.254 255.255.255.0
ip nat inside
speed auto
interface FastEthernet1/3
description *** Outside Internet - ISP A***
ip address dhcp
ip access-group firewall in
ip nat outside
speed auto
interface FastEthernet1/4
description *** Outside Internet - ISP B ***
ip address dhcp
ip nat outside
speed auto
ip nat inside source list 109 interface Ethernet0 overload
ip classless
no ip http server
no ip http secure-server
ip access-list standard 109
permit ip 192.168.1.0 0.0.0.255 any
permit ip 10.220.16.0 0.0.0.255 any
logging buffered 4096 debugging
logging trap debugging
line con 0
exec-timeout 15 0
login
password [login password]
line vty 0 15
exec-timeout 15 0
login
transport input ssh telnet
end
Scott Perry
Indianapolis, Indiana
________________________________________
Re: router help needed ....urgent - Part 2 - Policy Based Routing
Here is your policy based routing config (part 1 of 2):
interface FastEthernet 0/1
ip policy route-map dualisp
interface FastEthernet 0/2
route-map dualisp permit 10
match interface FastEthernet1/0
set interface FastEthernet1/2
route-map dualisp permit 20
match interface FastEthernet1/1
set interface FastEthernet1/3
route-map dualisp permit 30
This is the basic framework of policy based routing (PBR) and was not tested
for your implementation. Reference policy based routing on Cisco's website
throught the following links:
Link #1 - About PBR
www.cisco.com
Products and Services
Cisco IOS Software
IP Routing and Services
IP Routing
Policy Based Routing (PBR)
Link #2 - Configuring PBR
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a008075fae6.html
I would recommend testing this and then making variations. The above
configuration may not be as flexible to allow inter-LAN routing between
FastEthernet1/0 and FastEthernet1/1. Try changing the "match" statements to
"match ip address [access-list number]" to set the conditions of what the
inbound traffic criteria is. Try changing the placement of the policy to
function on the LAN interfaces if this provided configuration does not work.
Perhaps placing the policy on the LAN interfaces and setting the match
criteria different will work better. Try it out and make sure you do your
research (read the documents).
Scott Perry
Site Timeline
- » Making The Pirate Bay obsolete
- — Next thread in » Cisco Certification
- » Cisco confirms design cert track may reach CCIE level
- — Previous thread in » Cisco Certification
- » iPhone SUPER 80% discounts
- — Newest thread in » Cisco Certification
- » Faster internet is a top priority for the legislature. But how can NC get there? [...
- — The site's Newest Thread. Posted in » General Telecommunications Forum
