RIP v2
Does RIP v2 by default support VLSM or not?
Thank You,
Victor
vreyesii
Thank You for the reply.
vreyesii
RIP V2 supports VLSM but will not support it by default, you have to turn off auto-summarization.
D
genki
Not necessarily.
Two different concepts. They might or might not work together.
Drake
Yes - that's the main point of RIP2.
Paul Matthews
So to take advantage of VLSM with RIP v2 one has to turn off auto-summarization? So RIP v2 does not support VLSM by default?
Thank You
vreyesii
To enable VLSM RIP v2 passes the mask along with each route so that the subnet is EXACTLY defined.
RIP v2 supports the use of classless routing in which different subnets within the same network can use different subnet masks, or VLSM.
Gibo®
Yes
Frenz, Hope all r fine, NETWORKING Materials for Beginners,.. Check out all Links ,its too usefull for NETWORKING students..
Thanks Regards
OSI
Important Networking Q & A
TCP /IP Review
Basic Networking Q & A
EIGRP Q & A
http://c> Does RIP v2 by default support VLSM or not?
Suveetha
