Now with pictures!
Subject
- Posted on
Re: Problem with OSPF route
- 02-10-2008
Yeah the two routers are fully adjacent, here is the info:
On GROUCHO:
GROUCHO#show ip ospf neighbor
Neighbor ID Pri State Dead Time Address Interface
192.168.3.1 1 FULL/ - 00:00:35 192.168.2.1 Serial0/0
GROUCHO#
On CHICO
CHICO#show ip ospf neighbor
192.168.4.2 1 FULL/ - 00:00:38 192.168.2.2 Serial0
192.168.3.2 1 FULL/ - 00:00:34 192.168.3.2 Serial1
CHICO#
Your configs are a bit messy :-)
First thing I'd do, is to remove eigrp and rip. I can't imagine why you
would want or need to run more than one routing protocol on the same links.
It's considered bad practice. Also remove all eigrp-related stuff, like
authentication, from interface configuration. EIGRP has a lower
administrative distance than OSPF, and most likely adversely interferes
with it.
Second, remove access-groups (in and out) from CHICO's serial0, since they
are not defined anywhere.
Third, you have asymmetric bandwidth/cost configurations for GROUCHO's s0/0
and CHICO's s0. On GROUCHO, you declare an OSPF cost of 300, while on CHICO
the cost is left at its default value (which is 10^8/bandwidth, or
10^8/10^6, or 100). Having different costs for a link at the opposite sides
is not recommended, since it can cause asymmetric routing. Either manually
adjust the costs, or the bandwidths, or remove both altogether and go with
the default values.
After all the above, reload the routers and see whether things get better.
Thanks for the advice, I'll try your suggestions. The configs are a bit
messy for two reasons:
1) I didn't erase the configs from the previos user
2) I've been experimenting with many different settings & trying different
configs to try to understand all the concepts
I've nearly finished both ICND1 & ICND2 books so most likely I'll erase
everything and start again when I've finished the second book & covered all
the topics.
Cheers, Jase.
It looks like removing RIP & EIGRP solved the problem, I've learned
something as I thought even if the administrative cost for a route was
lower it would at least be displayed in a 'show ip route' command so long
as it was UP & there were no other authentication / config problems. Thanks
for taking the time to look into the problem for me.
Jase
Jason wrote:
You can also check for all ospf routes using 'show ip ospf database'.
Also.... Don't post your passwords....
jbeasley@jbeasley-desktop:~$ echo password 7 02000B5000031D7318 |
ios7decrypt.pl
password fokker24
jbeasley@jbeasley-desktop:~$ echo password 7 071C3543400C0B0A041718 |
ios7decrypt.pl
password stoneroses
jbeasley@jbeasley-desktop:~$ echo password 7 050D09042A495C5B4D |
ios7decrypt.pl
password fokker24
jbeasley@jbeasley-desktop:~$ echo password 7 1316031D0509162538213B |
ios7decrypt.pl
password stoneroses
ios7decrypt.pl
password fokker24
ios7decrypt.pl
password stoneroses
ios7decrypt.pl
password fokker24
ios7decrypt.pl
password stoneroses
Here are the 2 running configs, 192.168.4.2 is the ip address of another
ethernet port on GROUCHO which is 'DOWN' at the moment. I have been
using it to get my Internet connection working through my Cisco kit by
plugging my 3Com modem into it. OSPF just chose this IP address to use
as the ID for GROUCHO.
GROUCHO#show run
Building configuration...
Current configuration : 2362 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname GROUCHO
boot system tftp c2600-is-mz.121-27b.bin 192.168.1.50
boot system flash
aaa new-model
aaa authentication login default local
aaa authorization exec default local
enable secret 5 $1$FyMK$Zrr0VmdGOD3vNYR75Rjzf.
enable password 7 121A0C041104
username Jason password 7 02000B5000031D7318
ip subnet-zero
no ip domain-lookup
ip host HARPO 192.168.3.2
ip host CHICO 192.168.2.1
ip host SWITCH 192.168.1.2
ip dhcp excluded-address 192.168.1.1 192.168.1.9
ip dhcp excluded-address 192.168.1.25 192.168.1.255
ip dhcp excluded-address 192.168.1.17 255.255.255.0
ip dhcp excluded-address 192.168.1.12 255.255.255.0
ip dhcp excluded-address 192.168.1.11 255.255.255.0
ip dhcp pool Jason
network 192.168.1.0 255.255.255.0
default-router 192.168.1.100
dns-server 4.2.2.2 4.2.2.3
domain-name jason.co.uk
lease 7
no ip bootp server
key chain jason
key 1
key-string 7 01100F175804
interface Ethernet0/0
description LINK TO LAN
ip address 192.168.7.1 255.255.255.0 secondary
ip address 192.168.1.100 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no ip mroute-cache
full-duplex
no cdp enable
interface Serial0/0
bandwidth 100000
ip address 192.168.2.2 255.255.255.252
ip authentication mode eigrp 99 md5
ip authentication key-chain eigrp 99 jason
ip ospf cost 300
no ip mroute-cache
interface Ethernet0/1
description LINK TO INTERNET
ip address 192.168.4.2 255.255.255.0
ip nat inside
no ip mroute-cache
full-duplex
router eigrp 99
network 192.168.1.0
network 192.168.2.2 0.0.0.0
auto-summary
router ospf 5
log-adjacency-changes
network 192.168.1.100 0.0.0.0 area 0
network 192.168.2.2 0.0.0.0 area 0
network 192.168.7.1 0.0.0.0 area 0
router rip
version 2
network 192.168.1.0
network 192.168.2.0
network 192.168.7.0
ip nat inside source list 102 interface Ethernet0/0 overload
ip nat inside source static udp 192.168.1.17 32459 interface Ethernet0/0
32459
ip nat inside source static tcp 192.168.1.17 32459 interface Ethernet0/0
32459
ip classless
no ip http server
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
access-class 1 in
end
CHICO#show run
Current configuration:
version 12.0
hostname CHICO
enable secret 5 $1$7F47$eFaUV7zrDHoKuM7oQFV0F/
username EAGLE1 password 7 1316031D0509162538213B
username Jason password 7 0115090F500E145D75
ip subnet-zero
no ip domain-lookup
ip host GROUCHO 192.168.2.2
ip host HARPO 192.168.3.2 255.255.255.0
isdn switch-type basic-ni
key chain jason
key 1
key-string 7 070C285F4D06
clock timezone BST 0
interface Serial0
description LINK TO GROUCHO
bandwidth 1000000
ip address 192.168.2.1 255.255.255.252
ip access-group jason2 in
ip access-group jason out
no ip directed-broadcast
clockrate 64000
interface Serial1
description LINK TO HARPO
ip address 192.168.3.1 255.255.255.252
clockrate 64000
interface TokenRing0
no ip address
shutdown
interface BRI0
no ip address
encapsulation ppp
shutdown
router eigrp 99
network 192.168.2.0
network 192.168.3.0
router ospf 5
network 192.168.2.1 0.0.0.0 area 0
network 192.168.3.1 0.0.0.0 area 0
router rip
version 2
network 192.168.2.0
network 192.168.3.0
ip classless
ip route 192.168.5.0 255.255.255.0 192.168.2.2
banner motd ^CThe old Eagle2^C
line con 0
exec-timeout 0 0
password 7 04481F0901245E411A1C16
logging synchronous
login local
transport input none
line aux 0
line vty 0 4
exec-timeout 0 0
password 7 120D001B1C0E18
login
end
Site Timeline
- » Making The Pirate Bay obsolete
- — Next thread in » Cisco Certification
- » Problem with OSPF route
- — Previous thread in » Cisco Certification
- » Multiple Jobs Corp - Corp. Windows Data Access Management - Information Security &...
- — Newest thread in » Cisco Certification
- » TalkTalk HG635 on VDSL with multiple static IP addresses
- — The site's Newest Thread. Posted in » Wireless Networking
