To successfully ping your own interface address, another router must send
> back the ICMP echoes and the echo replies.
>I have seen this...you can't ping the local FR interface, you can from a
> machine behind the router ping the interface.....
> JB
>> I ran across a Cisco's FAQ on the subject, unfortunately I got more
>> confused from reading the explanation as why one can't ping a local
>> frame-relay interface (the setup is similar to the one posted in
>> another thread, I pasted it to the end of the email), below is the
>> excerpt from Cisco:
>> "A: You cannot ping your own IP address on a multipoint Frame Relay
>> interface. To make a ping successful on a serial interface, an
>> Internet Control Message Protocol (ICMP) echo packet must be sent, and
>> an ICMP echo reply packet must be received. Pings to your own
>> interface address are successful on point-to-point subinterfaces or
>> high-level data link control (HDLC) links because the router on the
>> other side of the link returns the ICMP echo and echo reply packets.
>> The same principle applies with multipoint (sub)interfaces. To
>> back the ICMP echoes and the echo replies. Because multipoint
>> interfaces can have multiple destinations, the router must have
>> mapping for every destination. Because mapping is not made for our
>> interface address to point toward other routers, which would send our
>> ICMP packets back, the router does not have any layer-two to
>> layer-three mapping for its own address and does not know how to
>> encapsulate the packet. An encapsulation failure results."
>> My question is why should the router at the other end come into play
>> when I ping a local frame-relay interface. Cisco seem to indicate
>> that the ping somehow goes out on the wire (or the PVC) to the router
>> at the other end and comes back? Is this a limitation on Cisco router
>> in implementing serial interface or am I missing something here? Any
>> insight would be greatly appreciated.
>> John
>> ----------------------- referenced configuration setup
>> R1 (s0/0)--------(s0/0)R2(s0/1)--------(s0/0)R3
>> R2 is configured as FR switch with no ip addresses set (interfaces are >> dce
>> with clockrate)
>> R1 is:
>> interface serial 0/0
>> ip address 172.16.0.1 255.255.255.0
>> encapsulation frame-relay
>> R3 is:
>> ip address 172.16.0.2 255.255.255.0
>> mappings are:
>> -on R1
>> Serial0/0 (up): ip 172.16.0.2 dlci 203(0xCB,0x30B0), dynamic,
>> broadcast,, status defined, active
>> -on R3:
>> Serial0/0 (up): ip 172.16.0.1 dlci 302(0x12E,0x48E0), dynamic,
>> it looks ok. I can ping from R1 to R3 and (of course) from R3 to R1,
>> but I can't ping from R1 it's own serial interface and from R3 its >> serial
>> interface.
>> debug frame-relay packet
>> Type escape sequence to abort.
>> Sending 5, 100-byte ICMP Echos to 172.16.0.2, timeout is 2 seconds: >>
>> 02:25:04: Serial0/0:Encaps failed--no map entry link 7(IP).
>> 02:25:06: Serial0/0:Encaps failed--no map entry link 7(IP).
>> 02:25:08: Serial0/0:Encaps failed--no map entry link 7(IP).
>> 02:25:10: Serial0/0:Encaps failed--no map entry link 7(IP).
>> 02:25:12: Serial0/0:Encaps failed--no map entry link 7(IP).
>> Why can't I ping routers own serial interface????
