Question for Cisco Certification
Threaded View
Hello all:
Some one wants to sell CCIE Lab for home study as following for $800.00, is
it a good price? please advise.  Thanks.
1.     Two Cisco 3600 Series 3640 Routers having 16MB Flash, 64MB RAM, 4
Serial Interfaces (FRAME RELAY SWITCHES)
2.     Two Cisco 2600 Series 2610 Routers having 16MB Flash, 64MB RAM, 1
Ethernet port, 2 Serial Interfaces
3.     One Cisco 2600 Series 2612 Router having 16MB Flash, 64MB RAM, 1
Ethernet port, 1 Serial Interface
4.     One Cisco 2500 Series 2501 Router having 16MB Flash, 16MB RAM, 1
Ethernet Interface, 2 Serial Interfaces
5.     One Cisco 3500 Series WS-C3524-XL-EN Switch having 24 Fast Ethernet
Interfaces, 2 Gigabit Interfaces
6.     One Cisco 2900 Switch WS-C2924-XL having 24 Ethernet Interfaces
7.     5 Back to Back Serial Cables to connect Routers
8.     2 Console Cables to configure Routers and Switch
9.     8 Power Cables
10.   5 Ethernet Cables
11.   Bonus CD containing IOS of Routers and Switches to update according to
your needs. Also we will provide you TFTP Server Software and documents
about how to upgrade the routers to a different IOS, password recovery
procedures and much more. Our experts can also help you setup your lab when
you receive all equipment (free 1 hour session with our Cisco expert to
answer all your questions about connecting the equipment and making the lab
ready)
Re: Question for Cisco Certification
Hi Pat,
Why don't use dynamips for study? It works realy great.
Greetz
Richard
Dynamips, works great however there is no switch emulation, yes you can
use routers with the Ethernet modules, just not the same.
You can use some of the above list for a CCIE (R&S, I assume) Lab (the
3640's, needs more flash though) (the 2501 as backbone router).
However, I would follow a layout for building a lab.
Internetwork Expert has one
(http://www.internetworkexpert.com/resources/ccierack.htm ).
Some of the equip off of your list is used as alternative equipment on
IE's list
They also have studies based on Dynamips as well
(http://www.internetworkexpert.com/resources/iosonpc.htm ).
There is also rack rental available from here.
(http://proctorlabs.com/index.cfm/product/sku/pl0224 )
Also, here is the equipment you will be tested on (currently) on the R&S
Lab exam (http://www.cisco.com/web/learning/le3/ccie/rs/lab_equipment.html).
I have affiliation with any of the companies listed nor have I used
their products or services.  Just what I've come across in my searches.
IE's list
I have NO affiliation with any of the companies listed nor have I used
If all that equipment is operational, $800 is a pretty good (great)
deal.  Do a lookup on eBay to see what the going prices are for used
equipment.
Site Timeline
