Hello,
I just owned a 2519. I habitually work on more recent routers (2600). I m not able to administer the router. I m using a Cisco standard cable and the good parameters for hyperterminal (with "standard" and "good parameters" i mean that with this cable and this parameters it works with the 2600). => I dont think it is the cable or an hyperterminal parameter.
The Led "NMS" from the console module is green, but the led "IN BAND" is not green. I made a reset but no difference.
Any idea ?
Thanks.
