Problem with GNS3
Hi, I've been using version GNS3.05 beta for router practice. When I open one or two cosole sessions, my CPU utilization pegs at 100% and PC becomes unusable. I'm using a 1.7GHZ dual core intel processor w/2 Gig of RAM. I'm not running any other programs concurrently w/GNS3.
Does anyone have any tips on eliminating this problem? Are there any settings/options ?
Thanks in Advance..
jdrum12
[Default] jdrum12 ha scritto:
GNS3 0.5 is last stable version.
Yep, you should set up the idlepc value. Consult the new GNS3 tutorial, page 18.:
rai
jdrum12
No problem... BTW GNS3, and Dynamips for that matter, gives better performance on Linux, especially if you compare it to Vista. If you want to play with Linux, I would recommend openSUSE 11.0 because of famous 1-Click install technology which provides also GNS3.
rai
