Cisco Certification problem in connecting lansey ADSL modem with cisco catalyst 2950 switch.
Subject Author Date
problem in connecting lansey ADSL modem with cisco catalyst 2950 switch. Ravi 07-13-06
Posted by Ravi on July 13, 2006, 8:21 am
I have a Cisco catalyst switch 2950 and a broadband connection of 1
mbps from BSNL. I try to connect the Broadband connection with the
switch but unfortunately the communicatin between the ADSL modem and
switch would not up.
The port on which I connect the ADSL modem did not show the link up
status on the switch.
I already tried several possible configuration but all invain
If somebody have a Perfect solution just revert me back
With REGDS
Ravi
Posted by gene martinez on July 13, 2006, 12:20 pm
Can you connect to the ADSL with just a pc and see if the port works?
Also you might need a cross-over cable to connect the switch to the
ADLS port...
>With REGDS
>Ravi
Posted by Ron Snipes on July 13, 2006, 2:47 pm
I believe you must use a cross over cable from the ADSL modem to anything
else you connect it to, computer, router, hub, whatever.
give us a holler if you are not familiar with a cross over cable. Just look
at both ends side by side. If both color patterns are the same, it is a
straight thru cable. The orange and green color wires will be opposite. This
is a broad picture, not exact. Google Cross over cable for the exact info.
my .02 cents
Ron
> With REGDS
> Ravi
Posted via a free Usenet account from http://www.teranews.com
Posted by suresh zen on July 14, 2006, 5:10 am
No, you do not need a crossover cable to connect an ADSL modem to a PC or
Switch or whatever. You need straight thru, not crossover.
> look
> This
> my .02 cents
> Ron
>> With REGDS
>> Ravi
Posted by gene martinez on July 14, 2006, 6:48 am
Not on a pc, but maybe to a switch. The ADSL port is made to connect
to a pc connection. A switch port is the same as the ADSL port
(connection wise) so you may need a cross-over cable, unless the
switch or the ADSL has a switch that does the same thing as the
cross-over cable..
>> look
>> This
>> my .02 cents
>> Ron
>>> With REGDS
>>> Ravi
Similar ThreadsPosted
problem in connecting lansey ADSL modem with cisco catalyst 2950 switch. July 13, 2006, 8:21 am
uplink in catalyst 2950 switch April 20, 2008, 2:23 am
HELP --> 2501 and Catalyst 1900 switch problem. Cannot get e0 on router to come up when connected to any ports on switch @@@@ June 1, 2006, 9:29 pm
Modem DialIn AUX port problem September 30, 2006, 2:57 pm
Cisco 2950 Switch April 3, 2006, 2:54 pm
Routing & ADSL Problem February 20, 2005, 2:02 am
Problem with Cisco Switch Port Please Help August 23, 2005, 1:43 pm
2900 Series switch V 2950 switch September 7, 2006, 1:05 pm
connecting routers up to a switch March 11, 2006, 9:21 pm
Connecting a Switch to a Router April 1, 2006, 3:39 pm
Connecting a Switch 1900 to a Router 2503 June 17, 2005, 3:24 pm
Switch config help?2950 October 12, 2006, 6:10 pm
Newby 2950 switch question September 16, 2005, 10:25 pm
Re: Using SSH to connect to a Catalyst 1900 switch November 15, 2007, 1:57 pm
Block arp packets on Catalyst switch February 22, 2008, 8:18 am
